[MyDomoAtHome] Bêta version in nodeJS Topic is solved
- epierre
Re: [MyDomoAtHome] Bêta version in nodeJS
sure this way but not suitable for many people, some would like just a package, going on ssh and shell can br too hard... compared with a pré-installed domoticz image
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
- epierre
need some testers on :
- blinds devices
- push on / off buttons
- docker image
- blinds devices
- docker image
- epierre
0.0.19 version out with correction to waterflow, gas, multiswitch, dimmer
we'regetting close, need some tester on blinds please !
@epierre
Good morning,
I have tried to install the beta version in nodejs. I followed your install procedure as described on github.
- downloaded nodejs_4.4.2_armhf.deb and npm_2.14.7_armhf.deb from http://www.e-nef.com/domoticz/mdah
- sudo dpkg -i nodejs_4.4.2_armhf.deb gave me errormessages -> npm not found
- sudo dpkg -i npm_2.14.7_armhf.deb gave me errormessages -> nodejs not installed
Please advise.
Thanks a lot in advance for your help
Cheers
Josh
Good morning,
Please advise.
Cheers
Josh
- epierre
@josh send me your email so we discuss it on the slack support.
nodejs includes npm, your error is strange.
Maybe a dumb question, please forgive me if it is.
- Ive installed the nodejs version which installs fine and runs in usr/share and runs on a different port then the old mydomoathome
- I also still have the old mydomotathome in /home/pi/domoticz running on a different port
When I start the domoticz service, always both are starting up.
Is there a way to uninstall the old mydomoathome so it doesn't try to start that service anymore ?
- epierre
@bdormael to migrate:
- sudo service MyDomoAtHome.sh stop
- sudo rm /etc/init.d/MyDomoAtHome.sh
To have the new on same port:
- sudo vi /etc/mydomoathome/config.json
and change the port number
To completely remove it: rm -rf /home/pi/domoticz/MyDomoAthome if your user is pi
Perfect, thxepierre wrote:@bdormael to migrate:
Hello ..I'am Testing dimmer .
Domoticz server: http://192.168.0.200:8080
Node version: 4.3.2
MDAH version: 0.0.28
On and Off works ok..
But when setting level :
And sometime works ok .,:
On MDAH version: 0.0.19 all works ok .,
Edit:. MDAH version: 0.0.28 started this morning and it works., (cache , etc.) but works fine.,
and again got response 500 ., and now 200 .. I can not find a reason .
Node version: 4.3.2
http://192.168.0.200:8080undefined
::ffff:192.168.0.104 - - [21/Mar/2016:21:40:35 +0000] "GET /devices/73/action/setLevel/46 HTTP/1.1" 500 36 "-" "-"
http://192.168.0.200:8080/json.htm?type=command¶m=switchlight&idx=73&switchcmd=Set%20Level&level=12&passcode=
::ffff:192.168.0.104 - - [21/Mar/2016:20:55:45 +0000] "GET /devices/73/action/setLevel/75 HTTP/1.1" 200 16 "-" "-"
::ffff:192.168.0.104 - - [21/Mar/2016:21:54:34 +0000] "GET /devices/73/action/setLevel/74 HTTP/1.1" 200 16
Found that in : case 'setLevel' whet device_tab[deviceId].Action has Null value then go to :default and it works .
But more often have value "1" so go to case 1: .. so i add to case 1:
Don't know why it happens ..
else {
lsetLevel = Math.ceil(actionParam * (device_tab[deviceId].MaxDimLevel) / 100);
my_url = "/json.htm?type=command¶m=switchlight&idx=" + deviceId + "&switchcmd=Set%20Level&level=" + lsetLevel + "&passcode=";
I cant get my devices listed. My gateway is running.
When i give the command http://gateway_ip:gateway_port/devices the webpage returns at connection refused.
tried to set the 127.0.0.1 as domo_path. but same result.
If i set the domo_path to my domoticz ip adres 192.168.1.165:xxx in the gateway it will stay like this:
is that correct?
AppName: MyDomoAtHome
MDAH: http://192.168.1.165:3002
Domoticz: http://127.0.0.1:8080
NodeJS: v4.2.2
Webmanager: EJS
Renderer: Express
is that correct?
NodeJS: v4.2.2
Webmanager: EJS
Renderer: Express
- epierre
@Iowca is that better now ? version 0.0.37 around with instll fixes
@Justintime thanks for the Wiki correction
have you tried accessing the html page http://192.168.1.165:3002 ?
Re: RE: Re: [MyDomoAtHome] Bêta version in nodeJS
YW for the wiki. I was stuck on that one.epierre wrote:@Iowca is that better now ? version 0.0.37 around with instll fixes
Yes I can access the html page gateway.
In the other post you can see what it's reading.
When I change the json.htm in my internal ip and port it Wil stay on 127.0.0.1 in the html page. Is that correct?
- epierre
The "intrernal page" just reflects your configuration in /etc/mydomoathome/config.jsonJustintime wrote:YW for the wiki. I was stuck on that one.epierre wrote:@Iowca is that better now ? version 0.0.37 around with instll fixes
if you click on the links here you should see the results based on this configuration.
If you call http://192.168.1.165:3002/devices you should have a result, not a 4xx or 5xx code
info: Node version: 4.3.2
info: MDAH version: MyDomoAtHome 0.0.45
Unfortunately, the same .. i use mysensors 2.0 without radio as dimmer , maybe i do something wrong ,.
But add code from defautl: to case 1: i case 'lsetLevel' do the job ,. so its no problem .,
Btw: Great job.
Btw: Great job.
- epierre
@lowca can you send me the /json.htm?type=devices&filter=all&used=true&order=Name of your device ?
epierre wrote:@lowca can you send me the /json.htm?type=devices&filter=all&used=true&order=Name of your device ?
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "Set Level: 46 %",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 19,
"HardwareName" : "Mysensor2",
"HardwareType" : "MySensors Gateway with LAN interface",
"HardwareTypeVal" : 42,
"HaveDimmer" : true,
"HaveGroupCmd" : true,
"HaveTimeout" : false,
"ID" : "0000000",
"Image" : "Light",
"IsSubDevice" : false,
"LastUpdate" : "2016-03-26 21:39:29",
"Level" : 46,
"LevelInt" : 7,
"MaxDimLevel" : 15,
"Name" : "Dimm1",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Status" : "Set Level: 46 %",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "AC",
"SwitchType" : "Dimmer",
"SwitchTypeVal" : 7,
"Timers" : "false",
"Type" : "Lighting 2",
"TypeImg" : "dimmer",
"Unit" : 1,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "76"
- epierre
@lowca thanks for reporting, I've found things lost in translation, a v0.0.47 is out, can you test it ?
Short tests but it looks ok. Thxepierre wrote:@lowca thanks for reporting, I've found things lost in translation, a v0.0.47 is out, can you test it ?
- epierre
my pleasure !
