homebridge-edomoticz Plugin
- Marci
- Domoticz version: 3.8153
Re: eDomoticz Homebridge-Plugin
Have just checked everything over with v3.4834 - update via the webui worked fine, Domoticz comes back up cleanly, all plugin functions work fine. Safe to do an upgrade-in-place!
Extended Domoticz homebridge-plugin for latest Homebridge - adds temp/humidity/pressure sensors, power consumption sensors, DarkSkies virtual weather station support, YouLess Meter support, general % usage support & switch/lamp status checking!
- deejc
- Domoticz version: 3.5641
I use beta anyway, although the past few days have seen my zwave stuff misbehaving quite badly. I have bitten the bullet and ordered a Vera plus as I like the Vera gui and its stability
Domoticz 3.5641 on RPI (Raspbian GNU/Linux 8)
- Marci
Ah you’ll be moving over to @DamianXD’s homebridge-vera plugin then I presume... https://www.npmjs.com/package/homebridge-vera
- deejc
Yep, hopefully he is as diligent and helpful as you
- Marci
You can get an idea of the device support from https://github.com/damianxd/homebridge- ... ns.js#L106
- deejc
Seems a bit lighter than yours but my Thermo is Hardware HomeKit so don't need that and my other stuff is mainly switches lights and temps
Nice plugin! Set it up today and am totally impressed with it! Just a small issue I run into. I have my evohome system connected to domoticz. Setting the temperature through siri/Eve works but as soon as I touch the override timer button homekit crashes (see below loging-info). Also don't understand how the general "evotouch" device is working. It seems I can change it's temp in e.g Eve but that command is not recognized. Changing the Mode (currently Heating) to anything else (off/heat/cool/auto) does not seem to trigger anything.
[Domoticz] Setting thermostat SetPoint to 21
[Domoticz] Achterkamer sent command succesfully
Loaded plugin: homebridge-edomoticz
Registering accessory 'homebridge-edomoticz.eDomoticz'
Registering platform 'homebridge-edomoticz.eDomoticz'
Loaded config.json with 0 accessories and 1 platforms.
Loading 1 platforms...
[Domoticz] Initializing eDomoticz platform...
[Domoticz] Fetching Domoticz lights and switches...
Loading 0 accessories...
[Domoticz] Initializing platform accessory 'Achterkamer'...
[Domoticz] Initializing platform accessory 'Alexander'...
[Domoticz] Initializing platform accessory 'Circle afzuiger switch'...
[Domoticz] Initializing platform accessory 'Eettafel'...
[Domoticz] Initializing platform accessory 'EvoTouch Colour'...
[Domoticz] Initializing platform accessory 'Hue Gang'...
[Domoticz] Initializing platform accessory 'P1 Electricity'...
[Domoticz] Initializing platform accessory 'Voorkamer'...
Scan this code with your HomeKit App on your iOS device to pair with Homebridge:
[Domoticz] Static Data for EvoTouch Colour: 1
[Domoticz] Setting thermostat SetPoint to 10
[Domoticz] There was a problem sending command toEvoTouch Colour
[Domoticz] undefined
[Domoticz] Setting thermostat SetPoint to 10.5556
- Marci
Duly noted... the guy who originally asked for EvoHome support never fed back on it to let me know what worked and what didn’t (cos I don’t have one, so it’s rather tricky!), so ta!! Have tagged it onto the end of the open issue for it over on the repo - will hopefully look at it this weekend.
See: https://github.com/PatchworkBoy/homebri ... /issues/13
Could you get it’s JSON output (destructions in original post) and add it into the github log above?
Thanks for looking into this. Not exactly sure what you meant with the last comment. I've included the json description of the evohome control and from one of the zones. Is that what you meant?
"ActTime" : 1457201936,
"ServerTime" : "2016-03-05 19:18:56",
"Sunrise" : "07:18",
"Sunset" : "18:27",
"result" : [
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "Auto",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 1,
"HardwareName" : "HGI80",
"HardwareType" : "Evohome USB (for HGI/S80)",
"HardwareTypeVal" : 39,
"HaveDimmer" : false,
"HaveGroupCmd" : false,
"HaveTimeout" : false,
"ID" : "4be9a",
"LastUpdate" : "2016-03-04 16:36:02",
"MaxDimLevel" : 0,
"Name" : "EvoTouch Colour",
"Notifications" : "false",
"PlanID" : "2",
"PlanIDs" : [ 2 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Status" : "Auto",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "Evohome",
"SwitchType" : "evohome",
"SwitchTypeVal" : 0,
"Timers" : "false",
"Type" : "Heating",
"TypeImg" : "override_mini",
"Unit" : 0,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "1"
"status" : "OK",
"title" : "Devices"
"ActTime" : 1457202001,
"ServerTime" : "2016-03-05 19:20:01",
"Sunset" : "18:27",
"result" : [
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "21.8 C, (21.0 C), Auto",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 1,
"ID" : "",
"LastUpdate" : "2016-03-05 19:19:24",
"Name" : "Voorkamer",
"PlanID" : "2",
"PlanIDs" : [ 2 ],
"SetPoint" : 21.0,
"Status" : "Auto",
"SubType" : "Zone",
"Temp" : 21.80,
"Timers" : "false",
"Type" : "Heating",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "4"
"status" : "OK",
"title" : "Devices"
- Marci
Yep, perfect. The EvoHome support was written for EvoHome-via-script rather than EvoHome-USB but leave it with me - I'll get something working for it!
boudicca
thanks marci, great job today. all working perfectly under Jessie under the RPI3, already got Siri controlling the lights and also controlling via a dummy switch my Harmony Hub and the AV/Tv/and Sat box:)....got to say its so cool. Hey Siri, Turn on "the TV".
sbisbilo
I managed to put eDomoticz on a Raspi with Domoticz V3.4834. I'm using Eve on my iPhone and my iPad it's working perfectly, thanks to you Marci
But I've got a problem : I'd like to use another iPhone (my brother's) but Eve can't see Homebrige... If I change the username and the port in the config.json file it's working but of course my iPhone and my iPad don't.
Did somebody have this problem ?
Hope that is clear with my english/french language :p
Sylvain
Sylvain
- Marci
Just invite your brother's appleid via Settings > HomeKit from one of your devices. That bridge is already 'owned' by your appleid.
HomeKit apps on his devices should then automatically get the accessories list.
Nb: iCloud Drive needs to be enabled on all devices.
boudicca
Done a ikle write up on my wordpress for everyone.
https://mypocketfluff.wordpress.com/201 ... n-bbc-one/
sbisbilo
Thanks Marci I'm gonna try this
It's working !!! Yeah so cool !
Marci wrote:Just invite your brother's appleid via Settings > HomeKit from one of your devices. That bridge is already 'owned' by your appleid.
Thanks for looking at the issue. Saw on the other thread you suggested to update the homekit plugin to solve the crash problem with Evohome. I can confirm that now it's not crashing anymore but as mentioned there the override does not work as expected (the temps are set as a permanent override). Included the log of homekit when trying to do the temporary update.
I did program a button to execute a script when going to bed early to turn down the heating. It executes a similar action to what this is trying. Maybe the syntax will give you a pointer? the url I use is
/usr/bin/curl -s -i -H "Accept: application/json" "http://$DOMOTICZ_SERVER/json.htm?type=setused&idx=4&setpoint=15.0&mode=TemporaryOverride&until="$DATE"T00:30:00Z&used=true"
with $DATE being:
DATE=`date --date="+1 day" +%Y-%m-%d`
[Domoticz] Setting thermostat SetPoint to 19.5
[Domoticz] Setting thermostat SetPoint to 20
[Domoticz] Setting thermostat SetPoint to 20, mode to TemporaryOverride
[Domoticz] There was a problem sending command toAchterkamer
with $DATE being:
- Marci
Cool - ta. Still working on it bit-by-bit...!
sion
Hi guys,
apologies if im being a idiot and have missed something, but im struggling to get this off the ground
I had been playing with the original homebridge that came on the SD card that i insalled last november.
I couldnt get it workign properly, and as i was waiting to update domoticz anyway, i backed up the database, and downloaded and installed the latest SD image.
It now seems different to before, and i cant get anything going.
Even following the wiki to configure homebrige doesnt work.
After the fresh install, i no longer have a homebridge directory, just .homebridge -- whick only has the config file ,and the persist folder.
Im not sure if i need to be insalling homebridge, or if its already there, and also if i still need to install the edomoticz plugin or if thats already there...
Can someone point me in the right direction as to what first steps should be when starting with the latest SD image?
Many thanks,
S.
Many thanks,
S.
running domoticz 3.4834 on rpi2, with
Hue bridge / bulbs.
lightwave rf sockets, mood controlers, sensors & contacts.
Home bridge / Siri.
Ha bridge / echo Alexa.
Hard wired alarm system - setting home / away status.
Next: harmony hub.
Hue bridge / bulbs.
Home bridge / Siri.
Next: harmony hub.
sion
ok....
was being more of an idiot than i thought..
i just needed to boot up and type "homebridge" and everything worked..
S.
S.
Hue bridge / bulbs.
Home bridge / Siri.
Next: harmony hub.
Hue bridge / bulbs.
Home bridge / Siri.
Next: harmony hub.
pvm
- Domoticz version: 4.10538
Nice, thanks for the great description and tooling. One minor thing in the opening post:
should (in my case?) be
sudo curl -sL https://deb.nodesource.com/setup_0.12 | bash -
sudo curl -sL https://deb.nodesource.com/setup_0.12 | sudo -E bash -
