http://www.domoticz.com/forum/viewtopic ... 23&t=10834
Enjoy.
I've taken the liberty of publishing my security alarm code having found things so easy to write using dzVents compared to writing in native LUA.
Suggestions for improvements would be appreciated.
--[[ lua/scripts/phones.lua by commodore white
This dzVents script implements an android phone presence detector using the
Domoticz System Alive Checker (Ping) feature.
For each phone being monitored, you need two virtual devices, one that you bind to the System
Alive Checker, and another that keeps you informed of the phones proximity. I needed the second
because our phones kept losing and regaining connectivity as we moved around the house or we went outside
for a few minutes perhaps to the washing line.
The script is in two parts, the first responds to pings while the second implements a 'grace period' during
which time a phone can be out of earshot for a short while without raising the alarm.
The script also maintains another virtual device called "AnyPhone" which is On whenever any phone is
in reach.
My virtual devices are called:
Peter and pingPeter
Rita and pingRita, and
AnyPhone
... that is, 2n+1 virtual devices in total.
on = { "ping*", "timer" },
active = true,
execute = function(domoticz, _pingPhone)
local phone
local pingPhone
local GRACE = 10
local lost_or_found
local AnyPhone
local _AnyPhone
local _phone
local _pingPhone
printf = function(s,...) return print("dzVents Phones: " .. s:format(...)) end
_AnyPhone = domoticz.devices["AnyPhone"]
if _pingPhone ~= nil then
phone = _pingPhone.name:sub(5,99)
_phone = domoticz.devices[phone]
if _pingPhone.state == "On" and _phone.state == "Off"
then _phone.switchOn()
if _AnyPhone.state == "Off" then _AnyPhone.switchOn() end
AnyPhone = "Off" -- assume no phones found
domoticz.devices.forEach(function(_pingPhone)
if (_pingPhone.name:sub(1,4) == "ping") then
phone = _pingPhone.name:sub(5,99) _phone = domoticz.devices[phone]
m_phone = _phone.lastUpdate.minutesAgo m_pingPhone = _pingPhone.lastUpdate.minutesAgo
if _phone.state == "On" then -- recently seen
if _pingPhone.state == "Off" -- but currently not seen
and m_pingPhone > GRACE -- and has been so for several minutes
then _phone.switchOff()
printf("%s's phone lost %um ago", phone, m_pingPhone)
printf("%s's phone found %uh %um ago", phone, m_phone/60, m_phone%60)
AnyPhone = "On"
if _pingPhone.state == "On" and _phone.state ~= "On" then _phone.switchOn() end -- incase the ping was missed
printf("%s's phone lost %uh %um ago", phone, (m_phone+GRACE)/60, (m_phone+GRACE)%60)
end -- if phone.state
end) -- for each
if AnyPhone ~= _AnyPhone.state then _AnyPhone.setState(AnyPhone) end
end -- if ping
end -- function
} -- return
-- proximity.lua
active = true,
on = { 'Peter', "Rita"},
execute = function(domoticz, phone)
if phone.state == "On"
and domoticz.security == domoticz.SECURITY_DISARMED
then domoticz.notify(phone.name .. " has arrived home", '',
domoticz.PRIORITY_EMERGENCY,
domoticz.SOUND_SIREN)
domoticz.notify(phone.name .. " has arrived home - ALARMS ON", '',
end -- function
--[[ /lua/scripts/security.lua
This script handles the Security Panel. When security is enabled it first checks if any doors or windows
are alarmed and reports it via messaging.
Shortly after security is enabled, the alarms are enabled and disabled immediately security is disabled.
You'll need to create a virtual device called AlarmsEnabled to use this script.
active = true,
on = { "Security Panel", "AlarmsEnabled",
"timer" },
execute = function(domoticz,_device)
DELAY = 30
_AlarmsEnabled = domoticz.devices["AlarmsEnabled"]
-- If the Security Panel has changed state
if _device == domoticz.devices["Security Panel"]
then
if domoticz.security == domoticz.SECURITY_DISARMED
then
if _AlarmsEnabled.state == "On" -- prevent spurious disarm events
then _AlarmsEnabled.switchOff() end
-- check if any doors or windows are alarmed
openings = 0
-- disregard perimeter sensors for now
domoticz.devices.forEach(function(_sensor)
if (_sensor.name:sub(1,3) == "msc")
and _sensor.state == "Alarm"
then openings = openings + 1 end
end) -- for each
-- perimeter alarms
then message = "Alarms already enabled"
else message = "Alarms enabled in " .. DELAY .. "s" end
if openings == 0
then domoticz.notify("Property seems secure", message)
else domoticz.notify(openings .. " openings need securing", message) end
-- schedule alarms to be enabled in DELAY seconds if its not already On
if _AlarmsEnabled.state ~= "On"
then _AlarmsEnabled.switchOn().after_sec(DELAY) end
end -- security panel state is disarmed
end -- if security panel state changed
-- If the Security Panel state was changed to DISARMED while the alarms are waiting
-- to be enabled, switch Off the alarms. Shame there's not a cancel function.
-- Notify everyone when alarms have been enabled or disabled
if _device == _AlarmsEnabled
then
if _device.state == "On"
then domoticz.notify("Alarms enabled", '')
else domoticz.notify("Alarms disabled", '') end
end -- function
--[[ /lua/scripts/motion.lua by commodore white
Report PIR and door/window opening/closing events unless alarm reporting is disabled
sounds a fire alarm if security is high unless a registered phone is nearby
disarmed or
suspended armed home armed away
internal | No No Notify+Siren
perimeter | No Notify Notify+Siren
active = true,
on = { 'pir*', -- internal detectors
"msc*" -- perimeter detectors
execute = function(domoticz, _detector)
-- test mode: no alarms if someone is at home, comment out for normal operation
-- if domoticz.devices["AnyPhone"].state == "On" then return end
if domoticz.security == domoticz.SECURITY_DISARMED then return end -- don't report if security is DISARMED
if domoticz.devices["AlarmsEnabled"].state == "Off" then return end -- ... or if alarms are temporarily suspended
if _detector.name:sub(1,3) == "pir" -- ignore internal detectors in
and domoticz.security == domoticz.SECURITY_ARMEDHOME -- low security mode
then
return
domoticz.notify('SECURITY BREACH', _detector.name:sub(4), domoticz.PRIORITY_EMERGENCY, domoticz.SOUND_SIREN)
if domoticz.security == domoticz.SECURITY_ARMEDAWAY -- in high security mode
and domoticz.devices["AnyPhone"].state == "Off" -- check no one is at home
then
domoticz.devices["Siren"].switchOn() -- then set off the siren
end -- execute
}Code: Select all
--[[ /lua/scripts/fire.lua by commodore white
Notifies which alarm has been triggered
All fire alarms have names that begin with the characters "fire", for example, fireLounge, fireGarage, etc
active = true,
on = { "fire*" },
execute = function(domoticz, _sounder)
if _sounder.state == "On" then
local DURATION = 40
domoticz.notify("FIRE ALARM: " .. _sounder.name, '',
domoticz.devices["Alarm"].switchOn() -- turn on the notify system
end -- if sounder On
end -- function
}Code: Select all
--[[ /lua/scripts/PanicButton.lua by commodore white
Always report panic button presses. There's one in my aged relatives bedroom (panicBedroom),
one in their bathroom (panicBathroom), and another by the front door (panicFrontDoor)
If any panic button is pressed, then the "Alarm" button is turned on.
active = true,
on = { 'panic*'},
execute = function(domoticz, _panicbutton)
local _alarm = domoticz.devices["Alarm"] -- Get id of alarm button
domoticz.notify("PANIC BUTTON", _panicbutton.name:sub(6) .. ' button was pressed')
if _alarm.state == "Off" then _alarm.switchOn() end -- enable the Cancel Panic button
end -- execute
}Code: Select all
--[[ /lua/scripts/doorbellpush.lua by commodore white
Notify if any door bell was pressed
Ignore multiple presses within a minute, you need a "BellPressed" variable for this
to work
active = true,
on = { 'bell*' },
execute = function(domoticz, _bell)
if domoticz.variables['BellPressed'].lastUpdate.minutesAgo > 1
then
domoticz.notify("DOOR BELL", _bell.name:sub(5) .. ' bell was pressed')
domoticz.variables['BellPressed'].set(0)
end -- execute
}Code: Select all
--[[ /lua/scripts/Notify.lua by commodore white
['timer'] = 'every 5 minutes',
"Alarm"
active = true,
execute = function(domoticz, _alarm)
local DURATION = 20
if _alarm ~= nil
then
if _alarm.state == "Off" -- alarm just got cancelled
then
-- commandArray["OpenURL"]="http://192.168.1.22:8080/json.htm?type=command¶m=resetsecuritystatus&idx=86&switchcmd=Normal"
domoticz.devices["fireLanding"].switchOff()
domoticz.notify("Alarm cancelled",' ')
m_alarm = _alarm.lastUpdate.minutesAgo
if _alarm.state == "On" -- Alarm still active ?
then -- If so, ...
if m_alarm < DURATION
then
domoticz.notify ("Alarm raised " .. m_alarm .. "m ago", "Visit Control Panel to clear")
_alarm.switchOff()
end -- end if alarm
end -- execute
Peter
