Set TEXT of a virtual text device with spaces
Number8
Domoticz version: 2022.1
Post by Number8 »
I'm trying to set the value of the TEXT virtual device using bash and curl, the value having spaces.
I have no problems with the following command in a brower
http://192.168.21.240:8080/json.htm?type=command&param=udevice&idx=217&nvalue=0&svalue=Please power ON this gear
However when using this code
message="Please power on this gear"
messageIDX=217
curl --silent $DOMOTICZSERVER:$DOMOTICZPORT'/json.htm?type=command&param=udevice&idx='$messageIDX'&nvalue=0&svalue='$message
Only the first word is displayed. I tried many things including escaping the single quote. At best only the first word of the message is displayed, or using many other solutions I tried an error is trigerred on the server side.
Any clue?
Thank you
Debian buster on NUC and three RPi with buster.
gizmocuz
Re: Set TEXT of a virtual text device with spaces
Post by gizmocuz »
try do some url encoding
message="Please%20power%20on%20this%20gear"
RobertH
Post by RobertH »
Use %20 for space.
Sent from my SM-G925K using Tapatalk
Domoticz running on Windows Server 2008 in VMware (ESXi), UZB1 stick, 3x FIBARO FGD212 Dimmer, 1x FIBARO RGBW Controller FGRGBWM-441, 2x FIBARO FGMS001 Motion Sensor and 2x Popp 009006 Plug-in Switch
paulvha
Post by paulvha »
I expect the issue with argument passing to curl. try double quotes : "$message"
Number8
Post by Number8 »
Thanks guys, it did the trick. I'm using the same idea to display accented characters
fyi double quote was one of my first tries. It does not work.
