Support of Gembird Siver Shield
rolandbreedveld
Domoticz version: 2021.1
Post by rolandbreedveld »
It would be nice if the GemBird Silver Shield will be supported
http://www.gembird.nl/item.aspx?id=3234&lang=de
4 switchable outlets controlled via USB
driver for Linux exists:
https://sourceforge.net/projects/sispmctl/
I compiled it on the Pi, example:
Request status:
# sispmctl -d0 -gall
Accessing Gembird #0 USB device 005
Status of outlet 1: on
Status of outlet 2: on
Status of outlet 3: on
Status of outlet 4: off
# sispmctl -d 0 -f3
Switched outlet 3 off
Raspberry Pi(SSD)+UPS HAT,Dashticz on WallTablet,HomeBridge, P1, HarmonyHub,FritzBox,API to 123Solar+ABB-PowerOne+SMA,ESP-Leds(flashed LSC),Tasmota,Shelly,MQTT,Mosquito,Node-Red,http://wiki.breedveld.net/index.php?title=RPiWaterMeter, Mercedes-Me
rolandbreedveld
Re: Support of Gembird Siver Shield
It works with Domoticz using a virtual switch and using a script for switching on/off
With a cron script, I update the Switch in Domoticz if the state is wrong.
but it would be nicer if it's supported from the app.
markcame
Post by markcame »
Which steps do you perform to install
I have a provblem running ./config with libusb dependencies
