(I am quite new to domoticz so maybe I am asking the obvious).
Have 2 Danfoss Living Connect LC13 valves. I included them in Domoticz, they are recognised in 'Hardware'. But in 'Devices' they are not visible so I cannot configure them or use them.
Is it a matter of not fully inclusion so I should try this again and again or is there something else?
Thanks for your reply!
Danfoss LC13 valve not visible in devices
Eisbeer
Re: Danfoss LC13 valve not visible in devices
In the network chart I see the nodes, but they are not connected to anything...
- Egregius
- Domoticz version: v2024.7
How can they appear under hardware if they are devices?
Not connected to any node means that they are to far away, or bad included.
First try a network heal. If not succesfull try exclude/include again.
- mbliek
Did you enable "accept new hardware" in settings?
Op zoek naar een Domoticz Start Set?
janneman001
- Domoticz version: 3.8153
I think I have a similar problem.
After pairing the Danfoss TRV it shows up under ozw and in the openzwave overview of devices. However it looks like it is not converted into a domoticz device. At least it does not show up with an idx in the devicelist.
ozw and domotiz zwave show it as a "Danfoss Living Connect Radiator Thermostat" and also generic type is setpoint thermostat.
I also have a Eurotronics Stellaz device that one shows up under devices as 4 devices in domoticz. 3 setpoints and one level device. I expected the Danfoss to show up as such. However does not (yet?)
Any ideas or advice?
- hoekstradj
- Domoticz version: V4.9700
I think I had the same problem with one my twoDanfos LC-13 thermostats: in nodes I could see both nodes but one with description "Danfoss Z Thermostat 014G0013" and the other with a blanc describtion. The node that had a describtion was visible in the list of devices and the other wasn't.
When I pressed the heal button behind the node and run to the thermostat to press the middle button (pressing once at the middle button of Danfoss LC-13 sends out a node information frame) the describion got filled in and the node appeared in the list of devices.
Best regards,
Dirk-Jan
Best regards,
Dirk-Jan
