AWST8802
manjh
Domoticz version: 2025.2
AWST8802
Post by manjh »
I have an AWST8802 switch from KAKU. It is basically a double switch, with two up/down buttons.
I want to use this as a pulse for a LUA script, as a counter.
Problem when I define the switch as on/off is that the status of the switch stays "on".
How can I process a single pulse?
Hans
mrf68
Re: AWST8802
Post by mrf68 »
Why is "always on" a problem? Domoticz will notice that On is pressed even if the status is On. So in my opinion you can script it like "if On then value is value + 1".
manjh
Re: AWST8802
Post by manjh »
Status stays "on". so the script will keep incrementing..
Hans
mrf68
Re: AWST8802
Post by mrf68 »
Take a look at this little video, I think it works.
http://weer.familie-frans.nl/domoticz/dc.mp4
manjh
Re: AWST8802
Post by manjh »
I tried, but it fails.
Code:
counter = otherdevices_svalues('KeukenLevel')
counter = tonumber(counter)
if devicechanged['Keuken schakelaar links'] == 'on' then
print ('increment')
counter = counter + 1
commandArray['UpdateDevice'] = 2 .. '|0|' .. tostring{counter}
elseif devicechanged['Keuken schakelaar links'] == 'off' then
print ('decrement')
counter = counter - 1
Log says:
Error: EventSystem: in Script_device_Schakelaar keuken links: [string "..."]:5: attempt to call global 'otherdevices_svalues' (a table value)
When I look at differences, the thing that jumps out is the definition of the counter. I tried creating a virtual device as counter, and it comes up in the utility tab as RFXMeter counter.
Can you give me the steps of how you created yours?
Hans
mrf68
Re: AWST8802
Post by mrf68 »
My 'Counter' is a virtual sensor, type Text. That is why I retrieve the info with otherdevices_svalues and convert it to a number so that I can calculate with it. When I read your 1st question, it wasn't clear to me what you wanted. Stating that an 'Always On' state is a problem, was something I doubted. I proved that it could work, with my video, I think.
Just typing over the code doesn't work. For instance, the '2' in 'commandArray['UpdateDevice'] = 2 .. '|0|' .. tostring(counter)' refers to the idx of my virtual Text sensor. The idx of your 'Keukenlevel' is probably not 2. And the '()' in 'counter = otherdevices_svalues('KeukenLevel')' needs to be '[]'.
What I did was:
create a switch, type Push On Button, name: PushOnButton
create a virtual sensor, type Text, name: Counter
Find the Idx for the virtual sensor (in Setup - Devices), in my case it is 2.
Then the script:
counter = otherdevices_svalues['Counter']
if
	devicechanged['PushOnButton'] == 'On'
then
This script won't work the first time, because the text sensor has no value. So you have to fill this text sensor with a numeric value. You can do that by replacing the first line with 'counter = 0'. Then revert the change.
After that, this script will read the value (as a string), then turns it into a number, and when the button is pressed, it will add 1 to the value and write is as a string in the text sensor.
Regards,
Martin
