I am moving from a LightwaveRF lighting setup to complete ZWave lighting and I am looking for the best way to set this up.
I am using AeonLab Micro ZWave Dimmer modules with seperate Nodon Zwave wall switches.
Micro Dimmers:https://www.intellihome.be/en/z-wave-ae ... -2399.html
Wall Switches:https://www.intellihome.be/en/z-wave-pl ... white.html
The reason I am using wireless wall switches is that I live in an older build UK house and none of my current standard switches have a 3 wire configuration, only 2 wire. Also, the Nodon switches are one of the few ZWave wall switches that are not a "paddle" type switch which I don't like the look of
The Nodon switches have 4 "buttons" which can be setup in 3 different modes:
- 1. Scene - Can be setup in Domoticz as a device. Each device (16 in total, 2 per button) can activate a scene.
2. Mono - Cannot be setup in Domoticz as a device. Each button talks directly to a node (dimmer). This can be done by including the node directly with the button or associating the button with the node in ZWave setup in Domoticz.
3. Duo - As Mono but the buttons are paired resulting in 2 On/Up buttons and 2 Off/Down buttons.
Do I include everything in Domoticz and manage it from there?
- Pros
- Everything can be controlled and managed from Domoticz and Domoticz App.
Scene Activation.
- It makes Domoticz very messy with lots of devices to do even a simple task.
There is a noticeable delay when switching the lights on. I assume this is because the button has to talk to Domoticz which then talks to the dimmer.
If my server goes down I can't use the lights!
- Pros
- Dimmers can still be controlled and managed from Domoticz and Domoticz App.
Cleans up the amount of devices in Domoticz.
Can still use the lights even if the server goes down.
No delay when switching the lights on.
- Not sure I can even do this. Is it possible to pair more than one device to another device??
Would need to constantly poll the dimmers so Domoticz can see the changes the switches are making.
No scene activation?? Not sure if this would still be possible in some way?
Another option I haven't thought of?
