MyDomoticz - Testers wanted!
Gabe
Re: Testers wanted!
Post by Gabe »
I will try this afternoon like new Installation let me see...
Gabe
Re: Testers wanted!
Post by Gabe »
I get now in the domoticz log follow error
2016-02-26 21:53:15.052 PROXY: Authenticate result: success.
2016-02-26 21:53:15.052 Error: PROXY: Read failed, code = 336130329. Reconnecting: decryption failed or bad record mac
2016-02-26 21:53:30.055 Error: PROXY: Read failed, code = 125. Reconnecting: Operation canceled
2016-02-26 21:53:45.060 Error: PROXY: Handshake failed, reconnecting: wrong version number
2016-02-26 21:54:00.063 Error: PROXY: Handshake failed, reconnecting: internal error
2016-02-26 21:54:15.066 Error: PROXY: Connect failed, reconnecting: Operation canceled
Hope someone could help me
Thx
Gabe
Re: Testers wanted!
Post by Gabe »
i found now the mistake, it is due the password which I set in Domoticz.
iF I delete it no problem more...
Could anybody fix it?
RaspberryPiDavid
Re: Testers wanted!
Post by RaspberryPiDavid »
I registered for MyDomoticz, and had it working a few days ago. However, now when I go to https://my.domoticz.com, I get ERR_Connection_Refused.
Any ideas? I am running Chrome on my Android phone, and it was working a few days ago. Is the server possibly down?
Minglarn
Domoticz version: v3.8153
Re: Testers wanted!
Post by Minglarn »
All I get is Domoticz Offline when i visit : https://my.domoticz.com/ :cry:
YOYO
Domoticz version: V2.23393
Re: Testers wanted!
Post by YOYO »
Hello!
I have signed up for the my domoticz service.
Unfortunately i only get these reports in my logs:
2016-03-05 18:57:29.500 Error: PROXY: Handshake failed, reconnecting: Connection reset by peer
2016-03-05 19:01:37.501 Error: PROXY: Handshake failed, reconnecting: Connection reset by peer
Is this a known issue??
Minglarn
Re: Testers wanted!
Post by Minglarn »
Same here...
Latest RPI beta version..
dakipro
Domoticz version: 3.5877
Re: Testers wanted!
Post by dakipro »
I also got handshake error, but after restarting the raspbpi it says Proxy success!
Now icon on MyDomoticz is green but when clicking it it takes me to my favourites but jumps right back to settings.
Then I figured that I have turned off "dashboard" and I use "floorplan" as my default screen, and when I turned those back localy, everything started to work fine, YAAAYY!!!!!!!
Now I do not have to bother with the router and think about the my own security setup, as I am sure you guys will do a much better job securing my raspbpi :)
Btw, I was 10 times clicking on the name of the dashboard for the settings, maybe not the most intuitive icon but it works when you know where to click
P.S. clicking on the remote version is "faster" then clicking locally, I was clicking around to compare it, and I didn't see any delay at all (I head to doublecheck which url I am looking as both local and remote are lightening fast!)
Raspberry Pi 2 B - MySensors (dimmers, switches, motion, temperature, lux, humidity sensors)
zWave (220v switches)
various 433 via RFLink
Minglarn
Re: Testers wanted!
Post by Minglarn »
Tried to reboot the RPI but with the same results.
Must be something else...
TruusDom
Domoticz version: 3
Re: Testers wanted!
Post by TruusDom »
pm send
Nooby user with
RPI2B / Aeotec Z-Stick gen5 / Aeon Sirene gen5 / FGSD002/ Fibaro door-window sensor / Fibaro Universal Binary Sensor / Keypad MG36B / Vison ZS5101 /Aeotec recessed door and window sensor with zwave plus / Weather Underground
dakipro
Re: Testers wanted!
Post by dakipro »
Ok, my remote version worked for around one day and then my.domoticz.com says that my client is offline.
I restarted the raspi and I got now again
2016-03-11 20:44:39.253 Error: PROXY: Handshake failed, reconnecting: Connection reset by peer
Is this some security or test feature? Can I get it back online, or do I apply for testing? :)
Or it is some "known" thing going on and it is expected to be back online
chimit
Domoticz version: master
Re: Testers wanted!
Post by chimit »
Okay, here's another update.
We are aware that mydomoticz is down at times. This is due to lack of having open-source development/debugging time by myself.
As a quick fix, there's a parachute process now that automatically restarts the service after it crashes.
Fingers crossed!
== Rene
Nass2
Re: Testers wanted!
Post by Nass2 »
do you still need tester ? I've created my account on MyDomoticz.
I'm ready to send feedback if needed
chimit
Re: Testers wanted!
Post by chimit »
Nass2 wrote:Hello,
Sure, you can just connect if you want to. And bug reports are always welcome, via this thread.
dakipro
Re: Testers wanted!
Post by dakipro »
Hi, is service up again, is anyone else getting the proxy handshake thing?
My system is
Last seen: 10-03-2016 18:06:17
Last visited: 11-03-2016 16:15:08
I had few restart since. Any guide or something that I missed on how to fix it?
This could easily be a premium service (affordable one hopefully :D ) then you guys would have more time to work on it and make it as stable and as secure as possible
woody4165
Re: Testers wanted!
Post by woody4165 »
I can propose myself fro testing.
Just created MyDomoticz account, set up the API key and password in the Domoticz settings and Apply.
In the Log I get:
2016-03-17 10:01:11.040 Proxymanager started.
2016-03-17 10:01:11.081 Active notification subsystems: (0/11)
and after one minute
2016-03-17 10:02:37.996 Error: PROXY: Handshake failed, reconnecting: Connection reset by peer
And the Istance ID does not appear.
What can I do and report?
Woody
thorbj
Re: Testers wanted!
Post by thorbj »
Hi, I tried to register, but I haven't recieved the confirmation email yet.
Maybe the email daemon is down?
2xRaspberry Pi Model 2 w/RaZberry z-wave chip (master/slave)|Fibaro Wall Plug|Fibaro Universal Dimmer 500W|Aeon Labs Multisensor|RFXtrx433E|Nexa WMR-1000|Nexa Pe-3|Nexa Remote|Nexa LGDR3500|Lightify Gateway|Lightify RGBW bulb
micha_pr
Re: Testers wanted!
Post by micha_pr »
have registered, received key.
Have tried at two different systems - result is the same (in log):
2016-03-18 07:52:18.156 PROXY: We were assigned an instance id: xxxxxxxxxxxxx. [real number removed]
2016-03-18 07:52:18.187 PROXY: Authenticate result: success.
2016-03-18 07:52:18.188 Error: PROXY: Read failed, code = 336130329. Reconnecting: decryption failed or bad record mac
2016-03-18 07:52:33.191 Error: PROXY: Read failed, code = 125. Reconnecting: Operation canceled
2016-03-18 07:52:48.195 Error: PROXY: Handshake failed, reconnecting: wrong version number
2016-03-18 07:53:03.198 Error: PROXY: Handshake failed, reconnecting: internal error
2016-03-18 07:53:18.201 Error: PROXY: Connect failed, reconnecting: Network is unreachable
2016-03-18 07:53:33.204 Error: PROXY: Connect failed, reconnecting: Network is unreachable
Any idea?
Michael Pruefer
http://www.zwave-review.com (German only)
http://www.SmartHome.Work (German only)
spikehome
Re: Testers wanted!
Post by spikehome »
started this week with domoticz.
got the py wednesday installed and configed everything.
yesterday the api key from my.domoticz and everything works very well.
now i hope the domoticz app can be used from the ineternet without opening ports.
(use now openvpn)
micha_pr
Re: Testers wanted!
Post by micha_pr »
Something "happen" last hour. Both Domoticz installations are now connected - without any change from my side.
Proxy is working (again?) ;)
Michael Pruefer
