adding Youless in Domoticz
Amsterdam020
Domoticz version: 3.5629
Post by Amsterdam020 »
I tried to add Youless in Domoticz under 'Hardware" with the following settings:
Remote Address: http://192.168.1.67
Port: 32848
Password : password
The device does not show up under devices.
In the log the following is registered:
2016-03-05 23:09:04.062 Error: YouLess: Error connecting to: http://192.168.1.67
2016-03-05 23:09:14.084 Error: YouLess: Error connecting to: http://192.168.1.67
2016-03-05 23:09:24.106 Error: YouLess: Error connecting to: http://192.168.1.67
2016-03-05 23:09:34.128 Error: YouLess: Error connecting to: http://192.168.1.67
2016-03-05 23:09:44.150 Error: YouLess: Error connecting to: http://192.168.1.67
What is wrong with my settings?
Rp3, youlesss, rfxcom, philips hue, dsb1820
Siewert308SW
Domoticz version: Stable
Re: adding Youless in Domoticz
Post by Siewert308SW »
Why port 32848?
default port in 80
Setup:
- RPi4 - Domo Stable / Aeotec Z-stick7 / PiHole Unbound Gemini
- RPi4 - PiHole / PiVPN Unbound Gemini
- Synology DS923+ / DS218j
- P1 Gas/Power, SmartGateway watermeter
- Fibaro switches, contacts, plugs, smoke/Co2 ect
- rootfs @ USB HDD
Amsterdam020
Also when i use port 80 Domoticz still cannot find the YouLess.
Youless is configered as followed...
IP Adres: 192.168.1.67
Gateway Adres: 192.168.1.1
Amsterdam020
I found the problem:
in the field "Remote Address:" the value was "http://192.168.1.67"
when i removed "http://" Youless appeared under Devices.
Siewert308SW
Amsterdam020 wrote:I found the problem:
Glad it is solved...
Setup:
- rootfs @ USB HDD
