Domoticz on Windows 10
- groetg
- Domoticz version: V2.4025
I installed domoticz on Windows 10, but nothinh happens when i go to 192.168.2.x:8080. Is domoticz not yet compatible with win10?
Master: RPI Model 2B
Sub 1: RPI Model 2B
RFX transmitter/receiver 433 Mhz
13 KAKU units (3 window sensors, 1 door sensor, 7 light switches, 1 dusk sensor, 1 motion sensor)
4 IP cam
Meteostick
OTGW
P1 cable
Davis Vantage Pro weatherstation (incl. solar/UV)
Sub 1: RPI Model 2B
4 IP cam
Meteostick
OTGW
P1 cable
tlpeter
Re: Domoticz on Windows 10
I didn't try but I ran it on W8.1 and there isn't much of a difference.
Did you install it as a service?
- groetg
Yes. Installed it as service. Do i have to do that??
Sub 1: RPI Model 2B
4 IP cam
Meteostick
OTGW
P1 cable
Sub 1: RPI Model 2B
4 IP cam
Meteostick
OTGW
P1 cable
- groetg
IT Works. Thanx.
Sub 1: RPI Model 2B
4 IP cam
Meteostick
OTGW
P1 cable
Sub 1: RPI Model 2B
4 IP cam
Meteostick
OTGW
P1 cable
RobDob
- Domoticz version: v2.2563
I also have it running fine on 8.1
What do you get if you run "netstat -a" from cmd? is 8080 listed in the port list?
Can you see a Domoticz process in task manager?
Are there any messages in the Windows event log? I see a bunch of message related to nssm that shows Domoticz starting and stopping.
I installed domoticz today on Windows 10 (home), but it looks like the webserver isn't working (WebServer(HTTP) started on address: :: with port 8080). I installed it also as service. I don't no what is wrong.
Below the console window:
2016-03-05 17:19:46.267 Domoticz V3.4866 (c)2012-2016 GizMoCuz
2016-03-05 17:19:46.270 Build Hash: 8219aa0, Date: 2016-03-05 15:17:39
2016-03-05 17:19:46.358 Sunrise: 07:13:00 SunSet:18:22:00
2016-03-05 17:19:46.358 EventSystem: reset all events...
2016-03-05 17:19:46.377 Active notification subsystems: (0/11)
2016-03-05 17:19:46.381 WebServer(HTTP) started on address: :: with port 8080
2016-03-05 17:19:46.748 WebServer(SSL) started on address: :: with port 443
2016-03-05 17:19:46.748 Proxymanager started.
2016-03-05 17:19:46.753 Starting shared server on: :::6144
2016-03-05 17:19:46.753 TCPServer: shared server started...
2016-03-05 17:19:46.758 RxQueue: queue worker started...
2016-03-05 17:19:49.103 Hardware Monitor: Warning, OpenHardware Monitor is not installed on this system. (http://openhardwaremonitor.org)
2016-03-05 17:19:49.104 EventSystem: reset all events...
2016-03-05 17:19:49.105 EventSystem: reset all device statuses...
2016-03-05 17:19:49.121 Hardware Monitor: Started
2016-03-05 17:19:49.134 EventSystem: Started
Any idea's?
Any idea's?
Number8
- Domoticz version: 2022.1
Just a quick idea, have you tried to disable the firewall?
Debian buster on NUC and three RPi with buster.
Hello Number8,
Yes I tried that already, but still the same "WebServer(HTTP) started on address: :: with port 8080". Also on other Win10 machines. Do I need to start or configure the webserver (part) differently?
