When we go outside we often check the Rainfall Forecast from:
http://www.weeronline.nl/Europa/Nederla ... er/4057340
We check the graphic (The one with the blue bars when it's going to rain) that is on this webpage.
It looks like this graphic uses data from:
http://gps.buienradar.nl/getrr.php?lat=52&lon=4
Is there a way to get this Rainfall forecast graphic (with blue bars) in Domoticz?
For clearance: No need for this to be able to switch things. Just the graphic itself.
Tom
Rainfall forecast as a graphic?
stlaha2007
- Target OS: -
Re: Rainfall forecast as a graphic?
Hi Tom,
Im nearby, but it depends on a few variables. Can you develop/code your own script(s)? Is the gps.buienrader.nl link giving you the 'right' forecast.
Have looked at both links. Thats why i say nearby (Apeldoorn). I use several sources, like my own Alecto Weatherstation, Adafruits BME280 and the build ins Forecast IO and WeatherUnderground.
As a look (right now) into the text-dump from gps.buienradar.nl it looks like: 000|10.30 000|10.35 000|10.40
Which in my opinion are expected milimeters rain and the there time.
A simple bash script with wget, grep and a curl to insert into Domoticz can give you a graph for rain. I dont know how to let domoticz handle previous and future time and values.
Is it an option to look into ForecastIO or WeatherUnderground first?
Grtz,
Stephan
Grtz,
Stephan
Awst6000
Hi Stephan,
I already tried ForecastIO or and WeatherUnderground, but there is no weatherstation near, so no valid results.
I'm currently testing with this script:
http://www.domoticz.com/forum/viewtopic ... 258#p46258
This script comes near to what I'd like to see on my Dashboard.
Tom
Tom
stlaha2007
- Target OS: -
Hi Tom,
Great script, seen it pass by a few times last summer, hope it will work for you.
Grtz,
Stephan
Grtz,
Stephan
Awst6000
So I'm testing with:
But I only see results in the Domoticz log. Nothing happens with the virtual device.
(The virtual device first has a rain symbol but after a short while it looks like a small bar with the Domoticz icon. No further info)
Where did it go wrong?
Txs
Txs
Awst6000
Can anybody help me out? I want to update 3 virtual devices. The first two work. The third does not.
commandArray[1] = {['UpdateDevice'] = RainTextIDX_1 .. '|0|' ..tostring(RainPredictionText)}
commandArray[2] = {['UpdateDevice'] = RainTextIDX_2 .. '|0|' ..round(RainPrediction/2.55,0)}
commandArray[3] = {['UpdateDevice'] = RainTextIDX_3 .. '|0|' ='On'}
What went wrong?
Txs
What went wrong?
Txs
jackslayter
- Domoticz version: stable
commandArray[3] = {['UpdateDevice'] = RainTextIDX_3 .. '|0|On'}
RPi2 + RFLink, Domoticz
Chacon - micromodule 200w, remote 3b, 2x module 1000w, remote 16b, smoke detector, door contact, 2x 3500w plug
Oregon - 3x Thgr122Nx / OWL - CM180 / TRC02_2 RGB / Cheap - PiR, door contact, Temp Hum / 4x REVOLT NC5461
Awst6000
Txs, but the third switch only switches off (After clicking it to on manually too).
Here's part of the code I play with:
-- minuten=15
minuten=30
RainPrediction = IsItGonnaRain(minuten)
-- RainmmHour=10^((RainPrediction-109)/32)
if (RainPrediction > 0 ) then
verw = 3
RainPredictionText=('Regen binnen '..minuten..' minuten. Op schaal van 0-100: '..round(RainPrediction/2.55,0))
verw = 2
commandArray[3] = {['UpdateDevice'] = RainTextIDX_3 .. '|0|Off'}
RainPredictionText=('De komende '..minuten..' minuten geen regen.')
-- print('-- Regen verwacht(0-255 hoe hoger hoe meer regen): '..RainPrediction..' binnen '..minuten..' minuten.')
print('-- Regen verwacht(0-255 hoe hoger hoe meer regen): '..round(RainPrediction/2.55,2)..' % binnen '..minuten..' minuten.')
print('-- ' ..RainPredictionText )
print('-- ' )
