Hey there
In the latest release you could be able to at a dummy RGBW switch
Been looking around but can't find it
Can someone point me in the right direction
Thx
How to RGBW switch ?
- Domoticz version: 3.4834
Re: How to RGBW switch ?
Go to Hardware, add a dummy if you don't already have one. Then click "Create Virtual Sensor" and choose "RGB".
Hope it's ok to continue here..
After creating the creating the virtual sensor - in the "Switches" tab, and when editing the settings for the sensor.
Which Switch Type should be used? (default for me is Dimmer). I also tried to save a color but the save feature doesn't stick.
EDIT: I also realize that I don't get it how to use the virtual sensor to control the actual physical lamp..
