Start with the basics, how to read out Toon and create a switch.marktn wrote:Maybe a good wiki is an idea? I see a lot in this post. But don´t know where to start.
send from tapatalk app.
Toon Energy Readings on Domoticz Topic is solved
- gielie
- Domoticz version: latest β
Re: Toon Energy Readings on Domoticz
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
- Domoticz version: 3.5305
my script "script_variable_verwarming.lua" looks like this:gielie wrote: Could you post the complete code and the name of your switches so I can compare.
local toonState = 'varToonState'
local toonScene = 'varToonScene'
local toonSwitch= 'toonScenes'
if uservariablechanged[toonState] then
if uservariables[toonState] == 0 then
commandArray['Variable:' .. toonScene] = tostring('Comfort')
commandArray[toonSwitch]='Set Level 40'
print('Toon ingesteld op scene Comfort')
elseif uservariables[toonState] == 1 then
commandArray['Variable:' .. toonScene] = tostring('Thuis')
commandArray[toonSwitch]='Set Level 30'
print('Toon ingesteld op scene Thuis')
elseif uservariables[toonState] == 2 then
commandArray['Variable:' .. toonScene] = tostring('Slapen')
commandArray[toonSwitch]='Set Level 20'
print('Toon ingesteld op scene Slapen')
elseif uservariables[toonState] == 3 then
commandArray['Variable:' .. toonScene] = tostring('Weg')
commandArray[toonSwitch]='Set Level 10'
print('Toon ingesteld op scene Weg')
elseif uservariables[toonState] == 4 then
commandArray['Variable:' .. toonScene] = tostring('Overig')
commandArray[toonSwitch]='Set Level 0'
print('Toon ingesteld op scene Overig')
gielie wrote:
Its not working, what is wrong?
Sorry for my delay... I didn't post the full script in the previous post because i thought it was kinda easy to figure it out. I am just starting with lua and wanted the script to be cofigurable so anyone can use it...
so here it is:
-- script_time_toonselector.lua
-- Reads the Toon Thermostat Setpoint Temperature and updates the
-- selector in Domoticz to represent the current Active State.
-- Off scene is an option, leave it out if not needed.
-- Action commands wil not be executed.
-- Settings: Configure as desired
-- Name of the switch with the temperature setpoint.
ThermostatSetPointName = 'Room Setpoint'
-- Temperature SetPoints.
HomeSetPoint = '20.50'
ComfortSetPoint = '21.00'
SleepSetPoint = '19.00'
AwaySetPoint = '17.50'
OffSetPoint = '6.00' --optional
-- Name of the selector for Toon
ToonSelector = 'Toon scenes'
-- Name of the levels in the selector
HomeLevel = 'Home'
ComfortLevel = 'Comfort'
SleepLevel = 'Sleep'
AwayLevel = 'Away'
OffLevel = 'Off' --optional
-- Values from each level name
HomeLevelValue = '30'
ComfortLevelValue = '40'
SleepLevelValue = '20'
AwayLevelValue = '10'
OffLevelValue = '0' --optional
-- End of settings
-- Toon Thermostat SetPoint:
ThermostatSetPoint = otherdevices_svalues[ThermostatSetPointName]
if (ThermostatSetPoint == HomeSetPoint) then
--print("SetPoint equals to Home");
if (otherdevices[ToonSelector] ~= HomeLevel) then
print("Updating '" .. ToonSelector .. "' selector to '" .. HomeLevel .. "'")
commandArray['UpdateDevice'] = otherdevices_idx[ToonSelector]..'|1|'..HomeLevelValue
elseif (ThermostatSetPoint == ComfortSetPoint) then
--print("SetPoint equals to Comfort");
if (otherdevices[ToonSelector] ~= ComfortLevel) then
print("Updating '" .. ToonSelector .. "' selector to '" .. ComfortLevel .. "'")
commandArray['UpdateDevice'] = otherdevices_idx[ToonSelector]..'|1|'..ComfortLevelValue
elseif (ThermostatSetPoint == SleepSetPoint) then
--print("SetPoint equals to Sleep");
if (otherdevices[ToonSelector] ~= 'Sleep') then
print("Updating '" .. ToonSelector .. "' selector to '" .. SleepLevel .. "'")
commandArray['UpdateDevice'] = otherdevices_idx[ToonSelector]..'|1|'..SleepLevelValue
elseif (ThermostatSetPoint == AwaySetPoint) then
--print("SetPoint equals to Away");
if (otherdevices[ToonSelector] ~= 'Away') then
print("Updating '" .. ToonSelector .. "' selector to '" .. AwayLevel .. "'")
commandArray['UpdateDevice'] = otherdevices_idx[ToonSelector]..'|1|'..AwayLevelValue
-- Optional
elseif (ThermostatSetPoint == OffSetPoint) then
--print("SetPoint equals to Off");
if (otherdevices[ToonSelector] ~= 'Off') then
print("Updating '" .. ToonSelector .. "' selector to '" .. OffLevel .. "'")
commandArray['UpdateDevice'] = otherdevices_idx[ToonSelector]..'|1|'..OffLevelValue
Screenshot:
- Domoticz version: 2.4031
Still can't figure out what is wrong. If i check the line it looks likes i didn't get any response from Toon.marcoheijkoop wrote:I'm getting this error when following above steps
Traceback (most recent call last): File "/usr/local/domoticz/var/scripts/toon2domoticz.py", line 33, in <module> state = toon.get_program_state() File "/usr/lib/python2.7/site-packages/Toon.py", line 108, in get_program_state self.retrieve_toon_state() File "/usr/lib/python2.7/site-packages/Toon.py", line 72, in retrieve_toon_state raise Exception('Incomplete response') Exception: Incomplete response
But i can't figure out why. If i login on Toon op Afstand everything looks fine
Thanks for the wiki link! That helps a lot.
With http://192.168.1.9:7979/json.htm?type=c ... 01&state=0 i can switch my toon.
Only with the virtual switch under domoticz, it doesn't work,
https://www.dropbox.com/s/nfypq3dmyd3sl ... 5.png?dl=0
I do see a error:
2016-03-01 19:36:45.071 Error: ToonThermostat: Error getting current state!
What is going wrong?
Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
Re: RE: Re: Toon Energy Readings on Domoticz
I get that error once in a while too. It's just eneco's crap server. They go down sometimes...marktn wrote:Thanks for the wiki link! That helps a lot.
I do see a error:
Just got one btw...
Thanks! But it also doensn't switch. When i paste the link in my browsers it works, only not in domoticz with a virtual switchkurniawan77 wrote:I get that error once in a while too. It's just eneco's crap server. They go down sometimes...marktn wrote:Thanks for the wiki link! That helps a lot.
I do see a error:
Just got one btw...
Re: RE: Re: RE: Re: Toon Energy Readings on Domoticz
That's strange, if it works in a browser then it should work in Domoticz, it does the same... Might try changing the IP to 127.0.0.1. Otherwise it's just a coincidence... You could check on eneco's forum for any info of the server being down or not.marktn wrote:Thanks! But it also doensn't switch. When i paste the link in my browsers it works, only not in domoticz with a virtual switchkurniawan77 wrote:I get that error once in a while too. It's just eneco's crap server. They go down sometimes...marktn wrote:
I do see a error:
Just got one btw...
kurniawan77 wrote:That's strange, if it works in a browser then it should work in Domoticz, it does the same... Might try changing the IP to 127.0.0.1. Otherwise it's just a coincidence... You could check on eneco's forum for any info of the server being down or not.marktn wrote:Thanks! But it also doensn't switch. When i paste the link in my browsers it works, only not in domoticz with a virtual switchkurniawan77 wrote: I get that error once in a while too. It's just eneco's crap server. They go down sometimes...
Just got one btw...
I have changed the ip adress but no succes. I can give you access to domoticz? Maybe a setting that is wrong.
Is this normal?
In the browser it works, then a problem at eneco is not possible.
https://www.dropbox.com/s/h37h3942zv6md ... 6.png?dl=0
Re: RE: Re: RE: Re: RE: Re: Toon Energy Readings on Domoticz
Why is your idx in the last post 3901 and in this one 4305?
[/quote]marktn wrote:kurniawan77 wrote: That's strange, if it works in a browser then it should work in Domoticz, it does the same... Might try changing the IP to 127.0.0.1. Otherwise it's just a coincidence... You could check on eneco's forum for any info of the server being down or not.
Is this normal?
https://www.dropbox.com/s/6ks7yab3wj9ow ... 7.png?dl=0
4305 is the virtual switch. The level set 30% is normal?
[/quote]kurniawan77 wrote:Why is your idx in the last post 3901 and in this one 4305?
Is this normal?
Re: RE: Re: RE: Re: RE: Re: RE: Re: Toon Energy Readings on Domoticz
Yep, that level 30 homemarktn wrote:https://www.dropbox.com/s/6ks7yab3wj9ow ... 7.png?dl=0
Is this normal?
Is your selector protected?
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: Toon Energy Readings on Domoticz
Any other ideas to get it work? I can give you access to domoticz!?kurniawan77 wrote:Yep, that level 30 homemarktn wrote:https://www.dropbox.com/s/6ks7yab3wj9ow ... 7.png?dl=0
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: Toon Energy Readings on Domoticz
I could give it a try... Beloof niksmarktn wrote:Any other ideas to get it work? I can give you access to domoticz!?kurniawan77 wrote:Yep, that level 30 homemarktn wrote:https://www.dropbox.com/s/6ks7yab3wj9ow ... 7.png?dl=0
kurniawan77 wrote:I could give it a try... Beloof niksmarktn wrote:Any other ideas to get it work? I can give you access to domoticz!?kurniawan77 wrote: Yep, that level 30 home
See PM
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: Toon Energy Readings on Domoticz
Nailed it!!! Issue solved by configuring your local IP addresses in settings (no username and password)marktn wrote:kurniawan77 wrote:I could give it a try... Beloof niksmarktn wrote: Any other ideas to get it work? I can give you access to domoticz!?
See PM
Thanks for helping!
- gielie
so here it is:
- FIBARO FGS223
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
