better hue integration?
prein
Re: better hue integration?
I am using the lua script posted above to check the hue status directly from the bridge. This is done every minute.
This is still a workaround. Can I be of some help somewhere?
florabora
I read this thread and love the workaround for status update and I want to take the challenge even one step further...
How would one be able to use coca switches to trigger a Hue and set a dim state?
Background; I would like to reuse my already mounted wireless 433mhz coca wall switches to trigger the Hue.
Currently they are triggering a coca dimmer built-in in the wall and I am using regular light bulbs right now.
I want to change them to Hue lamps
JustME125
- Domoticz version: 2.4547
I use kaku (coco) stuff all the time in combination with HUE. Simply detect the coco events and trigger Hue lights or scenes with domoticz. Using dimmers would be harder I think (I don't have any dimmers so I can't test it). I control various lighting scenes with coco remote through domoticz.
Greets!
Verstuurd vanaf mijn HTC One_M8 met Tapatalk
Greets!
Kjakan
- Domoticz version: 2024.2
I use Nexa LYCT-705 remote to control my Hue scenes. Guessing this is similar to Kaku, Coco?florabora wrote:I read this thread and love the workaround for status update and I want to take the challenge even one step further...
Don't have any dimmers so I don't know what kind of values you get from the dimmer, but if you get percentage like 10, 20, 30 and so on this could be done with a little work.
Take a look at my scripts below, maybe you can use something there.
Had an issue with my Hue hub and needed to reset the hub and lost all my scenes. To prevent that in the future I wanted to have the most common Hue scenes values stored in Domoticz.
Also use this common scenes from different scripts so I wanted the scenes values in one place. This is how I did it.
-- ~/domoticz/scripts/lua/functions.lua
local b = {}
-- Philips Hue bridge settings
local HueBridgeIP = "192.168.X.X"
local HueBridgeAPI = "XXXXXX"
-- Philips Hue light ID settings
function b.PhilipsHueID(light_id)
if light_id == "LivingRoom1" then light_id = 1 end
if light_id == "LivingRoom2" then light_id = 2 end
if light_id == "LivingRoom3" then light_id = 3 end
if light_id == "LivingRoom4" then light_id = 4 end
if light_id == "WorkRoom1" then light_id = 5 end
if light_id == "WorkRoom2" then light_id = 6 end
if light_id == "WorkRoom3" then light_id = 7 end
if light_id == "Hall1" then light_id = 8 end
if light_id == "Kitchen" then light_id = 10 end
if light_id == "AlertWorkRoom" then light_id = 13 end
if light_id == "AlertLivingRoom" then light_id = 14 end
return light_id
--Function for scene values
--light_id, state, bri, hue, sat, alert, colorType, colorTypeValue, effect
function b.PhilipsHueScenes(room, scene)
if (room == "Livingroom") then
if (scene == "Max") then
b.PhilipsHue("LivingRoom1", "true", 254, 14920, 144, "none", "xy", "[0.4595,0.4105]", "none")
b.PhilipsHue("LivingRoom2", "true", 254, 14920, 144, "none", "xy", "[0.4595,0.4105]", "none")
b.PhilipsHue("LivingRoom3", "true", 254, 14920, 144, "none", "xy", "[0.4595,0.4105]", "none")
b.PhilipsHue("LivingRoom4", "true", 254, 14920, 144, "none", "xy", "[0.4595,0.4105]", "none")
elseif (scene == "Relax") then
b.PhilipsHue("LivingRoom1", "true", 159, 10376, 201, "none", "xy", "[0.5282,0.3963]", "none")
b.PhilipsHue("LivingRoom2", "true", 159, 10376, 201, "none", "xy", "[0.5282,0.3963]", "none")
b.PhilipsHue("LivingRoom3", "true", 159, 10376, 201, "none", "xy", "[0.5282,0.3963]", "none")
b.PhilipsHue("LivingRoom4", "true", 159, 10376, 201, "none", "xy", "[0.5282,0.3963]", "none")
elseif (scene == "MovieMode") then
b.PhilipsHue("LivingRoom1", "true", 29, 12205, 250, "none", "xy", "[0.5455,0.4148]", "none")
b.PhilipsHue("LivingRoom2", "true", 29, 12205, 250, "none", "xy", "[0.5455,0.4148]", "none")
b.PhilipsHue("LivingRoom3", "true", 6, 5249, 115, "none", "xy", "[0.4891,0.3702]", "none")
b.PhilipsHue("LivingRoom4", "true", 6, 5249, 115, "none", "xy", "[0.4891,0.3702]", "none")
commandArray['Movie mode']='On' --Movie mode switch
elseif (scene == "Off") then
b.PhilipsHue("LivingRoom1", "false")
b.PhilipsHue("LivingRoom2", "false")
b.PhilipsHue("LivingRoom3", "false")
b.PhilipsHue("LivingRoom4", "false")
--Turn off "Movie mode" if On and other than Movie mode selected
if (otherdevices['Movie mode'] == 'On' and scene ~= "MovieMode") then
commandArray['Movie mode']='Off'
print("Turn Off Movie mode")
elseif room == "Workroom" then
b.PhilipsHue("WorkRoom1", "true", 254, 14920, 144, "none", "xy", "[0.4595,0.4105]", "none")
b.PhilipsHue("WorkRoom2", "true", 254, 14920, 144, "none", "xy", "[0.4595,0.4105]", "none")
b.PhilipsHue("WorkRoom3", "true", 254, 14920, 144, "none", "xy", "[0.4595,0.4105]", "none")
b.PhilipsHue("WorkRoom1", "true", 126, 14130, 179, "none", "xy", "[0.4845,0.4144]", "none")
b.PhilipsHue("WorkRoom2", "true", 126, 14130, 179, "none", "xy", "[0.4845,0.4144]", "none")
b.PhilipsHue("WorkRoom3", "false")
b.PhilipsHue("WorkRoom1", "false")
b.PhilipsHue("WorkRoom2", "false")
elseif room == "Kitchen" then
b.PhilipsHue("Kitchen", "true", 254, 14920, 144, "none", "xy", "[0.4595,0.4105]", "none") -- Kitchen max
b.PhilipsHue("Kitchen", "true", 130, 14920, 144, "none", "xy", "[0.4595,0.4105]", "none") -- Kitchen Relax
b.PhilipsHue("Kitchen", "false")
--Turn on/off Philips Hue Scene lights
function b.PhilipsHue(light_id, state, bri, hue, sat, alert, colorType, colorTypeValue, effect)
if state == "false" then
os.execute ('curl -X PUT -d "{\\"on\\":false}" http://'..HueBridgeIP..'/api/'..HueBridgeAPI..'/lights/'..b.PhilipsHueID(light_id)..'/state')
elseif state == "true" then
os.execute ('curl -X PUT -d "{\\"on\\": '..state..', \\"bri\\": '..bri..', \\"hue\\": '..hue..', \\"sat\\": '..sat..', \\"alert\\": \\"'..alert..'\\",\\"'..colorType..'\\": '..colorTypeValue..', \\"effect\\": \\"'..effect..'\\"}" http://'..HueBridgeIP..'/api/'..HueBridgeAPI..'/lights/'..b.PhilipsHueID(light_id)..'/state')
-- Function for checking Philips Hue On/Off state
function b.GetHueState(light_id)
local json = require ("dkjson")
local tmpfile = '/tmp/hueLight_'..b.PhilipsHueID(light_id)..'.txt'
os.execute('curl -s http://'..HueBridgeIP..'/api/'..HueBridgeAPI..'/lights/'..b.PhilipsHueID(light_id)..' > '..tmpfile)
local file = io.open(tmpfile)
local content = file:read()
local obj, pos, err = json.decode (content, 1, nil)
if err then
print ("Error:", err)
hue_state=(obj.state.on)
file:close()
os.execute('rm -f '..tmpfile..'')
--print (content)
return (hue_state)
-- Function for Alarm lights
function b.AlarmLights(status)
if status == "RedAlert" then
b.PhilipsHue("AlertWorkRoom", "true", 254, 65527, 253, "lselect", "xy", "[0.6736,0.3221]", "none")
b.PhilipsHue("AlertLivingRoom", "true", 254, 65527, 253, "lselect", "xy", "[0.6736,0.3221]", "none")
commandArray['Variable:AlarmLights-RedAlert']='1'
print("AlarmLights: Red Alert")
-- Timelapse alert. Only active between kl. 7:00 - 23:45
elseif (status == "Timelapse" and uservariables["AlarmLights-RedAlert"] == 0 and minutesnow >= 420 and minutesnow <= 1425) then
b.PhilipsHue("AlertWorkRoom", "true", 1, 44554, 224, "select", "hs", "[0.2175,0.1298]", "none")
b.PhilipsHue("AlertLivingRoom", "true", 1, 44554, 224, "select", "hs", "[0.2175,0.1298]", "none")
print("AlarmLights: Timelapse")
elseif status == "Off" then
b.PhilipsHue("AlertWorkRoom", "false")
b.PhilipsHue("AlertLivingRoom", "false")
print("AlertLights: Turned off")
if uservariables["AlarmLights-RedAlert"] == 1 then
commandArray['Variable:AlarmLights-RedAlert']='0'
-- Function for time difference
function b.timedifference(s)
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
t1 = os.time()
difference = os.difftime (t1, t2)
return difference
return bCode: Select all
-- ~/domoticz/scripts/lua/script_device_Lights.lua
package.path = package.path .. ';' .. '/home/pi/domoticz/scripts/lua/?.lua'
b = require('functions')
-- Living room: On (MAX)
if (devicechanged['$SceneLivingRoom_1-1'] == 'On') then -- Nexa LYCT-705 remote
b.PhilipsHueScenes("Livingroom", "Max") --Set scene "Max" in living room
print('Set scene "Max" in living room')
-- living room: Off
if (devicechanged['$SceneLivingRoom_1-1'] == 'Off') then
b.PhilipsHueScenes("Livingroom", "Off")
print('Turn Off lights in living room')
-- Living room: Relax
if (devicechanged['$SceneLivingRoom_1-2'] == 'On') then
b.PhilipsHueScenes("Livingroom", "Relax")
print('Set scene "Relax" in living room')
-- Living room: Movie mode
if (devicechanged['$SceneLivingRoom_1-2'] == 'Off') then
b.PhilipsHueScenes("Livingroom", "MovieMode")
if (otherdevices['IsDark'] == 'On') and (otherdevices['Night mode'] == 'Off') then
b.PhilipsHueScenes("Kitchen", "Relax")
print("Turn On Movie mode")
-- Workroom: Max
if (devicechanged['$SceneWorkroom_1-1'] == 'On') then
b.PhilipsHueScenes("Workroom", "Max")
print('Set scene "Max" in workroom')
-- Workroom: Off
if (devicechanged['$SceneWorkroom_1-1'] == 'Off') then
b.PhilipsHueScenes("Workroom", "Off")
print('Turn Off lights in workroom')
-- Workroom: Relax
if (devicechanged['$SceneWorkroom_1-2'] == 'On') then
b.PhilipsHueScenes("Workroom", "Relax")
print('Set scene "Relax" in workroom')
return commandArray-
florabora
Thought about it some more and maybe it's possible to work with user var in domoticz and some kind of a foreach statement in a script in order to change between a couple of presets?
For instance.
Default = 0
Switch on = var+1 = preset hue #1
Switch on = var+1 = preset hue #2
Switch on = var+1 = preset hue #3
Switch off = var-1 = preset hue #2
Switch off = var-1 = preset hue #1
Switch off = var-1 = preset hue #0
Would that be possible you think?
For instance.
Default = 0
JustME125
I did something like that in the past with a coco wall switch. Kept a variable with the number of the active scene and used the wall switch to do the +/-1 trick. All scenes also updated this variable in case I changed a scene through domoticz to keep track of the active scene. I abandoned that solution when my pi crashed and I didn't have a backup.
MatthijsPH
- Domoticz version: 3.5305
For anyone who is interested my script to check the status of all hue lights by looping until no more lights are found.
-- script to check Philips Hue light status (on/off)
-- m.hagenaars
-- feb. 2016
-- you'll need to install socket library & dkjson, more info can be found here:
-- http://www.domoticz.com/wiki/Upload_energy_data_to_PVoutput#Install_socket_library
-- http://dkolf.de/src/dkjson-lua.fsl/home
-- both need to end up in /usr/local/lib/lua/5.2
-- this time based script wil use the HUE api to check the current status of your lights as reported by the HUE bridge
-- the script starts with light #1 and checks if the status reported by your bridge corresponds with the status in Domoticz
-- if HUE state is not equal to Domoticz state then the script will correct the status in Domoticz
-- the script will keep looping until there are no more lights to check and will then stop
-- in order for the script to work it is important that the names of each light are exactly equal in both your bridge & domoticz
-- I suppose you know the names of the HUE switches in Domoticz, you can check the names in your bridge with the HUE app
-- more info on Philips HUE api and how to get/change your username can be found here:
-- http://www.developers.meethue.com/documentation/getting-started
-- configure Hue Bridge
local hueBridgeIP = 'your IP here'
local hueBridgeAPI = 'your username here'
-- do not change beyond this line
-- this part will get the Hue status
function getHueLight(id)
local http = require('socket.http')
local ltn12 = require('ltn12')
local json = require('dkjson')
t = {}
local url = string.format("http://%s/api/%s/lights/%s", hueBridgeIP, hueBridgeAPI, id)
b, c, h = http.request{url=url, sink = ltn12.sink.table(t), method='GET'}
huestring = tostring(table.concat(t))
local hue, pos, err = json.decode(huestring, 1, nil)
if (hue.name) then
hue_name = (hue.name)
hue_state = (hue.state.on)
stop = true
return hue_name, hue_state, stop
-- now check Hue state & correct Domoticz if needed
i = 1
repeat
local hue = getHueLight(i)
if hue_state == true and otherdevices[hue_name] == 'Off' then
commandArray[hue_name] = 'On'
print(string.format("Status %s corrigeren", hue_name))
elseif hue_state == false and otherdevices[hue_name] ~= 'Off' then
commandArray[hue_name] = 'Off'
i = i + 1
until(stop)
The latest beta should now trigger on/off actions if Hue lights are switched outside of Domoticz.
wmn79
- Domoticz version: 3.5033
That would be great! I'll try and see if I can test it this weekend. Will this also update the logs off the switches themselves when lights are switched outside of domoticz? Really appreciate your effort.
Yes, the logs should also be updated.
tcorneillie
can something like this be done for Niko Home Control lights too? I'm new to Lua, so i need some help...
thanks in advance
Kind regs,
Tom
thanks in advance
Kind regs,
Tom
