RFXtrx433E + RS-200 (missing old transmitter)
jmeyerdo
Post by jmeyerdo »
Hello!
I would like to add some old RS-200 switches (Conrad?!) to Domoticz via RFXtrx43E.
Unfortunately I lost the sender/transmitter. Is there any way to add them manually? I tried countless combinations already.
Which "Type" of "Switch" do I have to select in Domoticz?
Maybe this is of any help?
http://www.bengt-martensson.de/harc/conrad.txt
BR, Jens
manjh
Domoticz version: 2025.2
Re: RFXtrx433E + RS-200 (missing old transmitter)
Post by manjh »
Jens,
I don't know if this will help you.
I used these devices a long time ago, before I switched to KAKU/COCO. But I never throw anything away as long as it isn't broken, so I dug the receivers and the remote control out and tried.
After inserting new batteries in the RC I was able to program a receiver.
Then I tried "learning" the signal from the RC into Domoticz, and that went OK. It comes up as "Light switch, Europe, on/off". When I click the remote both the receiver and Domoticz recognize it.
Next step was to switch the receiver on/off from Domoticz. When I click the icon, Domoticz reports to switch on oroff, but the receiver does not react at all.
So it looks like Domoticz can successfully receive the signal, but the outgoing signal is not recognized by the receiver.
This is as far as I can go. Does it help?
If someone from the core team wants more info in order to support these devices, let me know.
Hans
jmeyerdo
Post by jmeyerdo »
Dear Hans,
thank you for this further helpful information.
For me it's helpful to "accept" that there seem to be no solution with my old devices (same for me - don't put anything in trash what is not broken finally).
Maybe for core team it's helpful to check for any error/bug (even if devices are old...).
Thank you!
manjh
Post by manjh »
No problem. I have four receivers plus a build-in ceiling dimmer, and the original remote control.
All units are not being used at the moment.
So if the core team needs some data or wants to experiment, let me know! :)
Hans
b_weijenberg
Post by b_weijenberg »
Hans, please contact support rfxcom.com for questions about device support on RFXtrx
RFX-433, RFX-433EMC, RFX-868
