MyDomoticz - Testers wanted!
- Minglarn
- Domoticz version: v3.8153
Re: Testers wanted!
Ok, but nothing happens when I try to connect...
Strange... Same for everyone or is it just me?
“When you eliminate the impossible, whatever remains, however improbable, must be the truth.” -Spock in Star Trek VI
- chimit
- Domoticz version: master
Re: Testers wanted!
I see. I didn't notice, because it worked for me.
It seems that I am in kind of some eternal long lived connection. But new https connections aren't accepted. Something like that.
Could you try again right now?
- Minglarn
Re: Testers wanted!
Now it works!
Online since 16:30:08 ...
Great!
Great!
- Minglarn
Re: Testers wanted!
And now it's down again...
I know it's beta, but could it bee something on my side?
What should I look for?
Domoticz v2.4623
2016-02-17 16:36:32.166 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
2016-02-17 16:51:56.706 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
2016-02-17 16:52:26.726 Error: PROXY: StartThread(): Exception: resolve: Host not found (authoritative)
edit: Did uncheck "Apps Allowed" and now it's back online again.....
Domoticz v2.4623
- Minglarn
Re: Testers wanted!
Strange, i can't open my.domoticz from my phone.
No response.
Trying: https://my.domoticz.com
Nothing happens.
Edit: Restarted Domoticz and now it connects again... Seems that the Domoticz is the guilty one here...
No response.
Nothing happens.
Re: Testers wanted!
Today i've tested the mydomo proxy service. Nice sollution but have a few questions;
- I can't scan the QR-code in my google authenticator app. There appears a message that the code is not an code for the authenticator app.
- Why is there no 2-factor authentication native in domoticz?
- Do i have to adjust the allowed-ip list? Or what happend when i leave it default?
Because when i click on the instance, the domoticz offline screen appear. Inside the lan everything is correct.
- chimit
Re: Testers wanted!
@Minglarn: The error message looks like it's a (local) DNS problem. Not sure.
- chimit
Re: Testers wanted!
- What QR authenticator are you using? Some apps are known to not work. Not sure why. Browse this very thread for apps that do work.Purejet wrote:Today i've tested the mydomo proxy service. Nice sollution but have a few questions;
- Native 2 factor authentication in Domoticz is on the wish list. It will be there when some developer (or you) pick(s) it up.
- Are you talking about the ip allowed white list in the Domoticz settings? You can safely leave it to what it was. Worst thing that can happen is that you need to enter your password, if you have password protection enabled.
- chimit
Re: Testers wanted!
Update on the MyDomoticz service:
There have been some fixes that appear to make the service more stable (until now). Please continue testing.
Also there is a pull request pending for updated MyDomoticz code in Domoticz itself.
== Rene
== Rene
- remb0
Re: Testers wanted!
I use an ssl certificate on my raspi pi. so domain: port 443 is working.
but in my.domoticz it's down.
also my 2 shared connections from my brother appears to be offline.
It's not clear that the service has some issues or the clients. How can we help or test it the best?
Re: Testers wanted!
Hi everybody,
I just install mydomoticz, but unfortunately I get no connection. DOmoticz will get MyDomoticz Instance ID: no problem.
I see My DOmoticz also on the Dashboard, but the Icon is still red. My actuall IP is none in the settings is it right?
COuld someone help me why the Icon will be not green.
- Varazir
Re: Testers wanted!
What do the log say? Look for proxy messages.
Sent from my Nexus 5 via Tapatalk
Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
Re: Testers wanted!
follow logs I found
Proxymanager started.
ccepting shared server connections via MyDomotiz (see settings menu).
PROXY: Authenticate result: IP not whitelisted.
but no error
but no error
- Varazir
Re: RE: Re: Testers wanted!
Ahh, then admin need white list youGabe wrote:follow logs I found
but no error
Re: Testers wanted!
so could I do something?
- Varazir
Re: Testers wanted!
@chimit need to do it. He will send you a message. He had to do it for me too.
Re: Testers wanted!
Thx
@chimit ccould you help me???
- chimit
Re: Testers wanted!
You can do it yourself. Login to my.domotic.com and edit the settings of your Domoticz instance. You can get there by clicking on the title ("My Domoticz" by default).Gabe wrote:Thx
Then make the box "Allowed ip addresses" empty. Or enter the ip address (not a host name) where your domoticz is allowed to connect from.
=+= Rene
Re: Testers wanted!
Hi everybody,
try it but no chance. It tell me everytime none also if I check my current ip it is everytime none...
Anybody a idea?
Anybody a idea?
- chimit
Re: Testers wanted!
Yeah, the field needs to be empty. Not "none"".Gabe wrote:Hi everybody,
Anybody a idea?
Sorry, the user interface is not clear here.
Users browsing this forum: binbo and 1 guest
