synology package : how to use x10 protocol
pipitch
Post by pipitch »
I want to switch my domoticz installation from raspberry to synology but I have some X10 devices.
How I can install mochad (or another) inside the synology to use X10 protocol.
I don't want to use chroot to do this.
G3rard
Domoticz version: No
Re: synology package : how to use x10 protocol
Post by G3rard »
Maybe you can use the following link from a Dutch Synology forum
http://www.synology-forum.nl/algemeen/x ... -synology/.
Not using Domoticz anymore
franzelare
Post by franzelare »
@pipitch: did you get it working?
I'm struggeling, on my Pi mochad workes fine, on my synology not.. and forwarding the switches works most of the time, but sometimes the status is displayed wrong on my synology... so that's why I would love to get mochad up and running on my synology
pipitch
Post by pipitch »
Yes and No. I use synology for all except x10. For the X10, I send the command to a raspberry (mochad is installed on rapsberry)
It's not the best way, but I will change my x10 device by zwave device.
franzelare
hmmm, than I just keep trying... since I have my entire house with x10 power line devices, since getting them in sync all the time will also be a lot of work.
I will let you know when I get it up and running!
jumbotroll
Post by jumbotroll »
Maybe I can cross compile the mchad binary into my domoticz package for synology, is that helping?
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
franzelare
if that's possible, would be great!
it would also need libusb 1.0 or higher to work
jumbotroll
franzelare wrote:if that's possible, would be great!
Libusb 1.0 is included in domoticz package also.
I can compile a test for you.
What NAS do you have and DSM version?
Jumbotroll
franzelare
I have a synology DS114 running on DSM 5.2-5644 Update 5
is that enough?
jumbotroll
Deleted, see next post.
Last edited by jumbotroll on Monday 22 February 2016 11:51, edited 1 time in total.
Jumbotroll
jumbotroll
Edit:
Packages deleted.
The package is reported not working
Last edited by jumbotroll on Tuesday 23 February 2016 22:44, edited 1 time in total.
Jumbotroll
franzelare
I have a MARVELL Armada 370
which package should I install?
jumbotroll
Edit.
Deleted
Last edited by jumbotroll on Tuesday 23 February 2016 22:43, edited 1 time in total.
Jumbotroll
franzelare
first time I will install a beta package.
I should stop domoticz, manually install this package?
jumbotroll
franzelare wrote:first time I will install a beta package.
Take backup of db and reinstall if you have a very old version.
Jumbotroll
jumbotroll
Edit:
The package is reported not working.
Jumbotroll
franzelare
hmm, i was planning to give it a try today, if you have an other revision, or have an idea how to get rid of my message:
configure: error: C compiler cannot create executables
jumbotroll
franzelare wrote:hmm, i was planning to give it a try today, if you have an other revision, or have an idea how to get rid of my message:
I have build standalone packages for mochad and netcat you can test.
You must install both packages.
http://www.jadahl.com/synology/?arch=armada370
Jumbotroll
franzelare
from the command line or from the package center?
jumbotroll
franzelare wrote:from the command line or from the package center?
Package center
I don't build bootstrap packages.
Jumbotroll
