Geofence for Domoticz
Evelen
Domoticz version: 2.4538
Re: Geofence for Domoticz
Post by Evelen »
worked bad today, when i come home it sent a off signal, and than it send some on and off singals when I was home.
Extended the range now, so i will test tomorrow
Pisellon1
Post by Pisellon1 »
Maybe a stupid question.
You have to take app GeoFence open on background?
Thank you
Appesteijn
Post by Appesteijn »
Pisellon1 wrote:Maybe a stupid question.
Thank you
If you have 'added a geofence' you can close the app. It will listen in the background and only gets triggered when you cross the geofence.
Pisellon1
Post by Pisellon1 »
Thank you for the info sir!
Guest
Post by Guest »
Does geofence not drain your telephones battery because the use of GPS??
Robert
Post by Robert »
RoadXY
Domoticz version: 2.2331
Post by RoadXY »
It uses several things to determine your location like wifi accesspoints it sees, connected phone cell towers and, only if necessary, GPS.
If you have Google Now enabled (or at least Google Location History) then your phone is already trying to figure out where it is every minute.
Off course it wil use some battery but most of the time not more then 5% - 10% on a full day of use (which off course is different on every phone).
According to several reports on internet, the Facebook app uses more! Even when not used. (Don't know if this is true: I don't use the Facebook app)
Evelen
Post by Evelen »
Have a request:
If the client does not get "ok" on JSON it should try again in a minute or something, now nothing happens if first JSON not reach Domoticz
Appesteijn
Evelen wrote:Have a request:
Do you get a timeout? The already checks if you have an internet connection and waits to call the url untill your phone has an internet connection.
Evelen
Post by Evelen »
my wifi on the phone is a litle unstable, it "has internet", but not realy.
Evelen
Post by Evelen »
argh, works bad, If i don't activate wifi it never now I'm home.
Appesteijn
Evelen wrote:argh, works bad, If i don't activate wifi it never now I'm home.
Could you try to set your radius to 500 meters? Then your phone wouldn't have wifi yet so your bad wifi can mess up the call to your server.
Evelen
Post by Evelen »
true, and that works, but i still need to have wifi on :P
Evelen
Post by Evelen »
even if i use 500M and wifi.
Sometimes when I'm at home it sends the "away/off" messages. then, after a few seconds it sending a "home/on" message. Sometimes it sending more "home/on" messages while I'm already home.
asjmcguire
Domoticz version: 3.5877
Re: RE: Re: Geofence for Domoticz
Post by asjmcguire »
Evelen wrote:even if i use 500M and wifi.
I even tried setting it to 5000 metres - it still does the switch on and off every 10 or so seconds sometimes for no reason at all. I gave up and turned the Geofence off - it's certainly not the only app that I've ever had Geofence problems with though, I blame Android.
Sent from my Nexus 4 using Tapatalk
AEOTEC ZStick, 11 ZWave Nodes, RFXCOMM, 50ish Byron Sockets.. HE851 (PIR), 2x HE852 (DoorContact)
WS2300, CM180, CC128, 2xTHGR122NX, 2xPiZeroW w/DS18B20, 8Ch 1W Relay Board.
8 Panasonic IP Cams, 1 16ch CCTV DVR + 15 CCTV Cams
Appesteijn
asjmcguire wrote: I even tried setting it to 5000 metres - it still does the switch on and off every 10 or so seconds sometimes for no reason at all. I gave up and turned the Geofence off - it's certainly not the only app that I've ever had Geofence problems with though, I blame Android.
You could try to look into your location history (there is a link in this topic), sometimes it helps to identify problems.
forum026
Post by forum026 »
Appesteijn wrote:
niclasc wrote: Does "Geofence added" and " Geofence removed" equals "on" and "off"?
Strange thing is that today it seams to work. But yesterday Geofence was "on" nomatter where I was
No, when you add a geofence, your phone will monitor when you enter the geofence (send on command) and when you leave the geofence (send off command). If you remove the geofence, your phone will stop monitoring and will never send on or off.
Good to hear it works now, if you need any help, just ask!
I have similar problem. The DomoFence is showing entering or existing zone correctly, but it seems not sending 'Off' to domoticz.
All seems to be correct configured (right buttom works fine).
Is there some kind of debug possible?
Appesteijn
forum026 wrote: I have similar problem. The DomoFence is showing entering or existing zone correctly, but it seems not sending 'Off' to domoticz.
If there are errors you should see them in a Toast (the short popup message). If your virtual switch does get switched on, the communication should be OK. And if the app give a notification when entering the geofence, that should work also.
You could also look into your location history at google and see if anything weird happens: https://maps.google.com/locationhistory/b/0
And you could try to see what happens when you place the geofence at another location (e.g. at work) to test if it works there.
RoadXY
Post by RoadXY »
The results in that website are flattened out.
If you want raw data use this app:
https://play.google.com/store/apps/deta ... ionhistory
In my case I saw that the location jumped around quit an bit.
forum026
Post by forum026 »
Appesteijn wrote: If there are errors you should see them in a Toast (the short popup message). If your virtual switch does get switched on, the communication should be OK. And if the app give a notification when entering the geofence, that should work also.
There were not error messages. This weekend I updated the Domoticz software to V3.xxx and now it's working fine. :D
