How do I tell if Domoticz can see the RFXCom
tre4bax
Post by tre4bax »
Hi there,
My rfxcom seems to be connected on a tty port for USB0 but when I try to use it nothing happens. Is there a log somewhere that can tell me if Domoticz is able to talk to the RFXCom or whether the fault is internal? Essentially how do I debug a non functioning rfxcom.
Just to eliminate the device itself. I'm setting up a new linux instance to do this with. The RFXcomm works fine with the original Raspberry pi based installation.
Any ideas would really help.
jannl
Domoticz version: 2025.5.x
Re: How do I tell if Domoticz can see the RFXCom
Post by jannl »
When you do a reboot, you should see the initialisation in the logfile
tre4bax
Post by tre4bax »
Ta Jannl. Do you mean the Domoticz log file or a linux one?
starfish001
Post by starfish001 »
tre4bax wrote:Ta Jannl. Do you mean the Domoticz log file or a linux one?
both Domoticz log and dmesg from shell.
I would reboot look at dmesg for rfxcom and the port it is using then check hardware tab within GUI ( perhaps reset the procotolcs) - if you check the Domoticz log you will see the port being used and the proctocols set.
