LUA Script not running, at all
Eloque
Post by Eloque »
I am trying to make a few simple lua scripts, but so far, I can't even get the simplest to run.
I've followed the instructions of renaming the demo scripts, but they never ever seem to trigger.
cat script_time_test.lua
print('this will end up in the domoticz log')
and cat script_device_light.lua
print('Light Test One')
if (devicechanged['Trap/Gang Licht'] == 'Off' then
        commandArray['Trap/Gang Licht']='On'
Both never seem to run, nothing shows in the logs, no devices change state, nothing. Is there something I am missing?
Holland
Domoticz version: Beta Ch
Re: LUA Script not running, at all
Post by Holland »
Are these placed in the directory? ; ~/domoticz/scripts/lua
Eloque
Post by Eloque »
Yes. Same place as the demo scripts were.
jannl
Domoticz version: 2025.5.x
Post by jannl »
Not sure if the '/' is allowed in the name of a switch
NickHead
Post by NickHead »
Try this:
My scripts are bracketed different.
May work, I am not an expert.
if (devicechanged['Trap/Gang Licht'] == 'Off') then
        commandArray[1]={['Trap/Gang Licht']='On'}
A lot of stuff that is doing my head in.
Eloque
Post by Eloque »
Trying that now. I'd be happy if even the log line appears :)
paulvha
Post by paulvha »
does the script have the right permission?
Eloque
Post by Eloque »
Nope. Nothing. The scripts don't seem to get executed at all.
What permission should they have? I'll try chmod'ing them to 777 to try just in case.
martijnhiemstra
Post by martijnhiemstra »
When you create the file script_time_test.lua domoticz expects a device called test to exist. The file name system works like this:
script_time_devicename.lua
This by the way will execute the script every minute. If you want to execute the script on every change then rename the script to:
script_device_devicename.lua
niceandeasy
Domoticz version: 3.8153
Post by niceandeasy »
Check your settings/other. Probably the event system is disabled.
NickHead
Post by NickHead »
Mine was called device_script_test.lua and i haven't got a switch called test.
It was to my belief that any script other than demo was run, the command being extracted
with the "devicechanged" section and acted upon.
Hence why I never included a filename.
As long as the device changed name is equal to the switch name ( as you said ) the script should act
accordingly.
NickHead
Post by NickHead »
As previously said:
Check Setup-Settings-Other, at the bottom is a Script-Enable/Disable Radio Button
Eloque
Post by Eloque »
NickHead, I found the setting, it was not disabled, blocky scripts are working btw.
I tried the old standby of turning it off and on again, and this showed up in the log;
2016-02-21 17:52:27.160  EventSystem: Stopped...
2016-02-21 17:52:27.168  Active notification subsystems: (0/8)
2016-02-21 17:52:33.027  (RFXCOM) Temp + Humidity (Sensor Reinder)
2016-02-21 17:52:41.826  EventSystem: reset all events...
2016-02-21 17:52:41.826  EventSystem: reset all device statuses...
2016-02-21 17:52:41.826  EventSystem: Started
2016-02-21 17:52:41.828  Active notification subsystems: (0/8)
2016-02-21 17:52:47.661  (RFXCOM) Temp + Humidity (Sensor Woonkamer)
And the scripts don't trigger. I'll try renaming the file next.
NickHead
Post by NickHead »
MMM Strange.
I am going to leave it with you for now as I have to go to work.
I will look back in later.
Siewert308SW
Domoticz version: Stable
Post by Siewert308SW »
Are you on the latest beta?
if so, check the forum... ;-)
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
niceandeasy
Indeed. I also discovered a bug in my system. Some things still work, some don't. Luckily, my lights are controlled by curl commands.
My time script gets triggered according to the log but it does not do anything.
(running newest beta)
Eloque
Post by Eloque »
About Domoticz
Version: 2.3029
Build Hash: 3b588dd
Compile Date: 2015-09-15 13:32:45
I'll try upgrading next.
Eloque
Post by Eloque »
Upgrading worked. Scripts run.
Siewert308SW
Eloque wrote:Upgrading worked. Scripts run.
Upgrading to what version?
Setup:
- DS923+ Docker
Eloque
Post by Eloque »
About Domoticz
Version: 2.4692
Build Hash: f42a1df
Compile Date: 2016-02-21 14:33:51
But, now Blocky scripts don't work at all :( Also, I can't set my SmartWares radiators to a temp, the devices don't show up. I can do it manually via the webinterface, but not via scripts.
