Cleaning IDX
u01pei
Re: Cleaning IDX
Post by u01pei »
I found it also impossible to work with and remember all the idx numbers when writing a script. the first solution was to start referring to a idx number.
for instance: smoke="123", now i can create a script line such as: if [ $smoke = On ]; then......
Problem with this method was when a IDX changed I had to check all the scripts where this device might be used and change the idx number. This problem also had a solution: creating a source file.
the source file is just another .sh file stating all of the idx references. every script I create the first thing to enter is:
source /home/pi/domoticz/scripts/Config.sh (the file extension does not really matter, it can also be .txt etc)
Now it is no longer needed to enter all the idx references separately. just start creating the script, using the references such as $smoke.
In the source file you can arrange your devices by type or location, whatever pleases you.
When you replace a device because it failed or needs upgrading, you just need to replace the idx number in one location: the source file.
Another benefit from the source file is the use of standard functions. The source file states:
# Format: SWITCHDEVICE $IDXdevice NewState
SWITCHDEVICE() {
curl -s "$SERVER/json.htm?type=command&param=switchlight&idx=$1&switchcmd=$2"
In a script i type this line for switching a light on:
SWITCHDEVICE $Livingroom On
I find it keeps the script more readable and I use this for just about everything you can find in the domoticz API/JSON wiki page. Also great for notification messages. Instead of a long url line I use one word (PUSHDOORBELL) for triggering the notification when the doorbell rings. again when debugging or just making changes to a script I don't have to scan trough each line to see what it's function is. Just one word tells me all (and does it all).
gizmocuz
Re: Cleaning IDX
Post by gizmocuz »
I am closing this topic as this does not make sense anymore.
We explained why/how it is used, and why you can not clean/reindex the IDX value of the tables, and this was the OP question.
Locked
