Logs shows the following
2016-01-03 11:40:16.479 (1 Wire) Temp (Sovrummet 2)
2016-01-03 11:40:17.972 (1 Wire) Temp (Vardagsrummet)
2016-01-03 11:40:19.353 (1 Wire) Temp (Källaren)
2016-01-03 11:40:20.733 (1 Wire) Temp (Sovrummet)
ls -l /pi@raspberrypi ~ $ ls -l /mnt/1wire/
total 0
drwxrwxrwx 1 root root 4096 Jan 3 11:42 10.11197E020800
drwxrwxrwx 1 root root 4096 Jan 3 11:42 10.B04883020800
drwxrwxrwx 1 root root 4096 Jan 3 11:42 10.C69E7C020800
drwxrwxrwx 1 root root 4096 Jan 3 11:42 10.CF2483020800
drwxrwxrwx 1 root root 4096 Jan 3 11:42 10.F12183020800
pi@raspberrypi ~ $ more /mnt/1wire/10.CF2483020800/temperature
-2.6875
15 1 Wire F121 33 Sovrummet Temp TFA 30.3133 23.9 C 12 100 [Remove Device] [Rename Device] [Log] 2016-01-03 11:47:19
14 1 Wire 1119 25 Källaren Temp TFA 30.3133 6.3 C 12 100 [Remove Device] [Rename Device] [Log] 2016-01-03 11:47:17
30 1 Wire C69E 158 Vardagsrummet Temp TFA 30.3133 28.8 C 12 100 [Remove Device] [Rename Device] [Log] 2016-01-03 11:47:16
31 1 Wire B048 72 Sovrummet 2 Temp TFA 30.3133 23.6 C 12 100 [Remove Device] [Rename Device] [Log] 2016-01-03 11:47:14
Is it possible to debug the 1wire interface more between Domoticz and OWFS?
Could it be that the sensor also reports some error codes and therefore not shown? (I don't think so since it shows the correct temperature in OWFS)
//Oskar
