Hi! I've searched on the forum to find the question I'm about to ask but could not find it. If it is already somewhere, please lead me!
On the attic I have a room where I do not come often. As I have found out, I sometimes forget te switch off the light and only see this the next time I come up there. This ofcourse is a waste of energy. I know I can send an automatic off-command after a set amount of time in the switch itself. I prefer to get a notification if the light is left on after a set amount of time so the light is not switcht off when I'm working there.
My idea is (in Blockly for I do not know LUA (yet)):
If the attic light is on for # minutes send notification with text "ABC".
Does anyone have an idea that works?
Kind Regards,
Robbert van der Gaag
Notification when switch is on after set time
Re: Notification when switch is on after set time
This Lua script will work:
-- script_time_garagedoor.lua
t1 = os.time()
s = otherdevices_lastupdate['Garagedoor']
-- returns a date time like 2013-07-11 17:23:12
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
difference = (os.difftime (t1, t2))
if (otherdevices['Garagedoor'] == 'Open' and difference > 600 and difference < 700) then
commandArray['SendNotification']='Garage door alert#The garage door has been open for more than 10 minutes!'
t1 = os.time()
- LdV46
- Domoticz version: stable
It worked!
I would not be able to reproduce this from scratch, but hey, it works!
- LdV46
I have an additional question about this one, maybe there is some documentation that describes this?
You chose to set the difference to 100 seconds (1 minute 40 seconds). I tested and it worked but I received 2 push-notifications. I changed the difference to 30 seconds and now I do not receive a single one.. What is the minimal difference?
- Westcott
It is a 'time' script (script_time_garagedoor.lua) so it runs every 60 seconds.
A 30 second difference might not be caught. 50% chance?
Whereas a 100 second difference can be caught twice.
- Domoticz version: 2022.2
Either that or use a virtual switch which you also set to prevent double notifications
