Problem with installing Z-Wave
richardschra
Post by richardschra »
Hello
I'm want to use a Aeotec Gen 5 usb stick to control my Danfoss living termostat. But i'm having problems with installing the software on my raspberry. I used the Wiki found on the domoticz.com ( http://www.domoticz.com/wiki/Installing ... spberry_PI )
But i get stuck in the step =
cmake -DCMAKE_BUILD_TYPE=Release CMakeLists.txt
The error that i get =
pi@raspberrypi ~/dev-domoticz $ cmake -DCMAKE_BUILD_TYPE=Release CMakeList.txt
CMake Error: The source directory "/home/pi/dev-domoticz/CMakeList.txt" does not exist.
Specify --help for usage, or press the help button on the CMake GUI.
It seems that the CmakeList not exists..
I'm already using Domoticz for 2 months, but only with a 433 transmitter. So i know something about Domoticz but Z-Wave is new for me
Does anyone know how I can solve this problem ?? Or is there a Domoticz image with the Z-Wave already configured ??
richardschra
Re: Problem with installing Z-Wave
Hello team, i'm still having problem with installing of the z wave stick... :?: :?:
Can somebody help me pleas ?
nayr
Domoticz version: github
Post by nayr »
your missing the source code, try git pull
jannl
Domoticz version: 2025.5.x
Post by jannl »
Open zwave is compiled in. I did not need to install anything when adding the aeon stick.
gizmocuz
Post by gizmocuz »
Try this:
mkdir ~/domoticz
cd ~/domoticz
wget http://domoticz.sourceforge.net/beta/domoticz_linux_armv7l.tgz
tar xvfz domoticz_linux_armv7l.tgz
rm domoticz_linux_armv7l.tgz
now you can start domoticz with:
./domoticz
with openzwave support build in
richardschra
jannl wrote:Open zwave is compiled in. I did not need to install anything when adding the aeon stick.
Hello guy's ! Thanks for your replays !
I'm starting al over again with a clean version of de raspberry wheesy sd card. I Will try "git pull" This time
@ Jan, did you use the domoticz sd .img for your instalation ? Or did you install domoticz by hand?
jannl
Post by jannl »
I used the domoticz image.
richardschra
Guy's , i did the hole instalation again with the 'git pull' and now iT works! Thanks for your help !
