Differences in Lua commandArray 'UpdateDevice' and OpenURL 'udevice'
Toni
Post by Toni »
I'm writing some event code based on virtual switches. Now I'm wondering about an inconsistency about the firing of subsequent events. I.e. my event script should cause device updates which fire other events.
So, if my Lua event script updates the status of an another device, I can do it in two ways: But why only the second alternative causes an event to be fired on the device I'm updating?
Siewert308SW
Domoticz version: Stable
Re: Differences in Lua commandArray 'UpdateDevice' and OpenURL 'udevice'
Post by Siewert308SW »
What about the following in for example a script_device_something.lua
When something triggers Lights to go ON then do something:
if devicechanged['Lights'] == 'On' then
commandArray['Do_Something']='On'
When something triggers Lights to go OFF then do something
if devicechanged['Lights'] == 'Off' then
When something triggers Lights to go ON or OFF then do something
if devicechanged['Lights'] then
Or do i misunderstand you?
Setup:
- RPi4 - Domo Stable / Aeotec Z-stick7 / PiHole Unbound Gemini
- RPi4 - PiHole / PiVPN Unbound Gemini
- Synology DS923+ / DS218j
- P1 Gas/Power, SmartGateway watermeter
- Fibaro switches, contacts, plugs, smoke/Co2 ect
- rootfs @ USB HDD
Toni
Post by Toni »
It's not that simple. What I want to update in my event script is a set of multiselectors, and I want the multiselector event to fire when the multiselector value is updated through the event script.
So I need to use the "commandArray['UpdateDevice'] = idx|nValue|sValue" format, instead of the "commandArray['Devicename'] = status". The UpdateDevice command does not fire an event on the updated device.
