RFXtrx firmware update 95/195/251
b_weijenberg
- Target OS: -
New firmware is available.
See blog.rfxcom.com
Lighting4 is improved and you can now enable ARC and Ligthing4 together.
Many cheap sensors equiped with the PT2262 or EV1527 are supported including Chuango.
Avantek (2300W/10A - with On/Off switch) is available at:
France http://www.amazon.fr/s/ref=sr_pg_3?rh=i ... 1454924251
Italy http://www.amazon.it/AVANTEK-Interrutto ... ds=avantek
US http://www.amazon.com/AVANTEK-Switches- ... ds=avantek
See blog.rfxcom.com
RFX-433, RFX-433EMC, RFX-868
Kubra
- Domoticz version: latest
Re: RFXtrx firmware update 95/195/251
Hoi Bert,
I notice in the new firmware that a "new PCR800" is added. I assume the protocol for this device (raingauge Oregon PCR800) is rewriten or adjusted in this new firmware release?
I couldn't find any new hardwaretype/release of the Oregon PCR800.
Can you be more specific of the changes for this device?
b_weijenberg
- Target OS: -
Code is added to support this new version.
RayAmsterdam
How do I add the Chuango motion sensors? Wich protocol?
deennoo
Re: RE: Re: RFXtrx firmware update 95/195/251
+1 did you allow to send chuango and does it works ?RayAmsterdam wrote:How do I add the Chuango motion sensors? Wich protocol?
http://domo-attitude.fr
RayAmsterdam
I don't see any signal from Chuango sensors.
b_weijenberg
- Target OS: -
RayAmsterdam
Good news Bert! When do you expect to release it?
olleman
Since this new firmware version I've re-added my PT2262 devices (just one at the moment) as Lighting 5 (BBSB). This one is a door sensor and I use it together with "On delay" to have the door be set "closed" automaticly after a few seconds. This operation is impossible to achive since the device is recognized as "lighting 5". It ignores the "on delay" command for the switch and it always stays closed. I have also tried to solve it with a simple event but it's the same...
Anyone know of a solution for this? I need this functionallity since the logic of my alarm depends on it.
,Olle
,Olle
erwindw
Hi there,olleman wrote:Since this new firmware version I've re-added my PT2262 devices (just one at the moment) as Lighting 5 (BBSB). This one is a door sensor and I use it together with "On delay" to have the door be set "closed" automaticly after a few seconds. This operation is impossible to achive since the device is recognized as "lighting 5". It ignores the "on delay" command for the switch and it always stays closed. I have also tried to solve it with a simple event but it's the same...
,Olle
Have you ever found a solution to this problem? I've updated the firmware of the RFXcom yesterday: all PT2262 sensors wich used to work perfect now aren't anymore. Domoticz now recognized them as Lightning 5 in stread of Lightning 4... thanks in advance!
Users browsing this forum: Bing [Bot] and 0 guests
