Can't include Fibaro FGD-212 dimmer
muddymickey
Hi all
First post here,and first adventure with Z-wave, as I try to replace some old X10 gear.
I have a Raspberry Pi running Domoticz, and have just bought a Razberry board.
I've set this up and added it as a device in Domoticz, looks OK as far as I can tell.
I have one Z-wave device that I am trying to include, a Fibaro FGD-212 dimmer (EU version).
In Domoticz, I try to include the node, and I set the FGD-212 up for inclusion, either by pressing my (retractable) wall switch quickly 3 times, or the "B" button quickly 3 times.
The LED lights red on the Razberry board - but then nothing happens. The dialog in Domoticz stays open, waiting for the device to include, but this never happens - the only option is to abort. When I do abort, the red LED on the Razberry goes off.
Any ideas what might be the issue ?
When I press the B button 3 times quickly on the Fibaro, should the LED on the Fibaro dimmer light up ? (It doesn't - just don't know if it should or not)
How can I be sure I've got the EU version of the Razberry ? The crystal seems to be marked "U" but I'm not sure what that indicates.
Thanks for any suggestions. Hopefully it's just me doing something daft...
muddymickey
Re: Can't include Fibaro FGD-212 dimmer
Perhaps should add I'm using Domoticz v2.3530 (I installed the Domoticz RPi image)
stuiow
- Domoticz version: 3.6857
I know this is an old post, but did you get them paired in the end?
I'm now in the same position. (using quick triple clock of B button).
Now setup on a RPI3.
Also using Evohome HGI80, RFXTRX433E and a Aeotec Gen5 stick. Mainly a Gen5 Z-Wave system.
My weather (Davis vantage Pro2) data is obtained by weatherunderground
Now collecting rtl_433 data from Apollo Ultrasonic meter
stuiow
Don't worry, i did a full reset of the dimmer, then tried again, all then went well.
Skippiemanz
- Domoticz version: 4.10233
What worked perfect for me was put domoticz in inclusion mode and then power the node. Worked perfect for me 9 out of 10 times!
tontze
- Domoticz version: Beta Ch
Hi, im in this situation right now, it looks like i cannot reset fibaro dimmer :/ I can cycle to yellow light, and pressing b-button once after that, it just doesnt give red blink, and cannot include node now
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
- blackdog65
I always go through the exclusion process 1st with every z-wave device... I learned this the hard way... then inclusion usually goes smoothly.
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
stuiow
Re: RE: Re: Can't include Fibaro FGD-212 dimmer
Have you turned the relay off for about a minute, then tried the reset procedure? From what i remember, you need to do that procedure within 30seconds of power on.tontze wrote:Hi, im in this situation right now, it looks like i cannot reset fibaro dimmer :/ I can cycle to yellow light, and pressing b-button once after that, it just doesnt give red blink, and cannot include node now
Sent from my SM-G925F using Tapatalk
tontze
Strange thing was, that when i triple clicked b-button for it to go inclusion mode, it turned lights on/off depending whether they were on or off...stuiow wrote:Have you turned the relay off for about a minute, then tried the reset procedure? From what i remember, you need to do that procedure within 30seconds of power on.tontze wrote:Hi, im in this situation right now, it looks like i cannot reset fibaro dimmer :/ I can cycle to yellow light, and pressing b-button once after that, it just doesnt give red blink, and cannot include node now
I then removed it from ceiling, only added L+N on it, red light turned on and it never did go off and i couldnt reset it this way either..
I did not wait that long tho, ill try it again later, its on the table now.
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
tontze
Ok, i made setup on the table, after fidling for a while with it, i managed to reset it and include it
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
