I have a question related to user Root : where can I find the login/password for login as root ? I installed Domoticz on a Pi2 using the default SD image, and I can't find the password.
I searched in the forum, but I only found a message telling "you should look at wiki".. but when looking in wiki, I only found one page about installation in another context, with password 1234.. but it doesn't work with root/1234.
I could read there are ways to make pi user behave like root (with sudo, but also in a "hardcoded" way), but what I'd like is to make sure I can log as root if I need to.
br,
Ricorico94
root privilege
ricorico94
Sneezydevil
Re: root privilege
You could just reset the password
Login with your pi user, and do:
I did not test this on a Pi but on a similar system, and I'm not saying I recommend doing this, I prefer using sudo.
sudo su
passwd
- gizmocuz
Re: root privilege
That latest line you do not need (passwd)
you should always use sudo, or issue
sudo su
no need to change the root password, or login as root
sudo su
