Scene triggers unwanted a LUA script
mischa
Domoticz version: 3.8872
Post by mischa »
I have the following script which set on a light based on the dim value of another light. see below
if (otherdevices_svalues['Overloop 1e etage'] > '10' and otherdevices['Trap'] == 'Off') then
	commandArray['Trap']='Set Level 1'
	elseif
	(devicechanged['Overloop 1e etage'] == 'Off') then
	commandArray['Trap']='Off'
I also have made a "all off" scene with a timer which set all my lights off, but somehow this scene triggers the script above and set the ['Trap'] lights to level 1
I don't understand why this happens, can anyone point me in a direction.
Thanks,
Mischa
Pi 2 - Pi 1 - Razzbery 2.0 - Fibaro FGD-211 - Fibaro FGD-212 - Fibaro FGRGBWM-441 (RGBW Module) - Fibaro FGBS321 (Universal Switch) - FGWPF-102 - TBK Home TZ67-G - Synology DS1515+ - Esp Easy (with wemos D1 mini)
Westcott
Re: Scene triggers unwanted a LUA script
Post by Westcott »
Should it be -
if (tonumber(otherdevices_svalues['Overloop 1e etage']) > 10 and ...
mischa
Post by mischa »
Westcott wrote:Should it be -
This is also working, but my scene still triggers the LUA script.
Don't think it matters using tonumber or the string value, as far as i know the svalues are stored as a string variable.
Dnpwwo
Post by Dnpwwo »
When a device value is set Domoticz will call 'device' scripts one after the other so if your Scene sets a device state your script will be called. This is expected behavior.
You need to extend your logic to make it only work when you want it to. Something like:
if (devicechanged['Overloop 1e etage'] ~= nil) then
     elseif
mischa
Post by mischa »
So if I do not check the device state (as I did in my script) the script will be executed when another device state is changed. Am I understand this correctly?
mischa
Post by mischa »
@Dnpwwo If i try your script I get the same behavior when scene is activated, deleted the scene and added again. But still the same behavior.
only my ['Trap'] lights are witched on, the are on a Fibaro RGB module.
jannl
Domoticz version: 2022.2
Re: RE: Re: Scene triggers unwanted a LUA script
Post by jannl »
mischa wrote:So if I do not check the device state (as I did in my script) the script will be executed when another device state is changed. Am I understand this correctly?
Correct
mischa
Post by mischa »
Correct
Why is it then that only this scene triggers my script and every other device change does not?
jannl
Post by jannl »
Every device change triggers every script. Only some exceptions when a script changes a device.
