Jango
Re: Domoticz app 2.0
Post by Jango »
Nice but any clue why it doesn't work?
RoadXY
Domoticz version: 2.2331
Post by RoadXY »
[edit]
Double post
Last edited by RoadXY on Wednesday 10 February 2016 16:18, edited 1 time in total.
RoadXY
Post by RoadXY »
Jango wrote:Week graphs for temperature are not working. Please could you improve readability for the graphs. Is that on the todo list?
V 0.1.230
Yes.
RoadXY
Post by RoadXY »
Jango wrote:Magnetic open / close relays now showed as switches with on/off function selection. This is not necessary for these types.
V 0.1.230
Could I get read only access to your server to test?
Send me an PM if so.
RoadXY
Post by RoadXY »
[edit]
Double post
RoadXY
Post by RoadXY »
bvduijv wrote:Temp Setpoint still not working in version 0.1.23. 3 screenshots below. First at opening the app. Second is after hitting 'set' en de third is after hitting the '+'. So the temp is initially set on 17, after hitting set it shows 16.5 instead of the 17 it was initially on. and after +0.5 the temp is suddenly 17.5.
Can you please have a look at it?
Yes, it's a known issue.
We are working on it.
LouiS22
Post by LouiS22 »
Guys, the built in server updater seems not working. It downloads the update, install is fine, but after opening the web interface, there's the popup about the very same update I installed from the app.
RoadXY
Post by RoadXY »
LouiS22 wrote:Guys, the built in server updater seems not working. It downloads the update, install is fine, but after opening the web interface, there's the popup about the very same update I installed from the app.
Something changed in the code on the server, I'm still unable to figure out why server is rebooting but not updating.
That's why we added a switch to disable the update check.
bitjeverkeerd
Post by bitjeverkeerd »
RoadXY wrote:
bitjeverkeerd wrote:Great app. I have one small "bug" with my Somfy screens (RFXCOM). In the "schakelaars" tabpage you can see the actual status (open or closed) but in the Dashboard tabpage (and also the "Ruimtes" tabpage) the actual status of the screens is invisible.
You can show or hide this in settings
Even with "instellingen/extra gegevens op.." "AAN" it's still not visible if the screens are open or closed.
RoadXY
Post by RoadXY »
bitjeverkeerd wrote: Even with "instellingen/extra gegevens op.." "AAN" it's still not visible if the screens are open or closed.
Gotcha. Will create an issue for it.
marktn
Post by marktn »
How to make a switch with on and off switch for a light switch.
Like switch lampen aan.
When my kaku does not respond it is not possible to give a extra light off function.
Verstuurd vanaf mijn SM-T800 met Tapatalk
Domoticz latest stable, Intel NUC, Proxmox, Zigate, RFLink, Kaku switches, Ikea lights, Xiaomi sensors, Honeywell smoke detectors, Yeelight, Shelly, Slave Domoticz PI 3B+, Node-Red, Espeasy.
RoadXY
Post by RoadXY »
marktn wrote:Hello,
Sorry, we can't help you with that.
marktn
Re: RE: Re: Domoticz app 2.0
Post by marktn »
RoadXY wrote:
marktn wrote:Hello,
Is it possible in a feature version?
How is the switch "lampen aan" made?
send from tapatalk app.
RoadXY
Post by RoadXY »
marktn wrote:Is it possible in a feature version?
Maybe if we get the request more.
bvduijv
Post by bvduijv »
Hi all, just downloaded the new beta and looked particular to the Setpoint functionality. Looks a lot better! But is not completely working as expected.. [SMILING FACE WITH OPEN MOUTH AND COLD SWEAT] I have created a screencast of it. It looks like the *.5 temperatures are not working fine and the animation at low temperatures is not looking very nice (not smooth).
See below for the screencast. If I can do something to help you solve it, please let me know.
https://dl.dropbox.com/s/cfbzlxpv39ml7e ... _42_07.mp4
lucaskywalker
Domoticz version: 2.353
Post by lucaskywalker »
It's a great App!
I am new in domoticz, i have a problem to open and to close my blinds with the apps.
I use Mysensors , and message type is S_COVER.
When try to open or close blind the senssor receive a message to stop it.
regards
RoadXY
Post by RoadXY »
bvduijv wrote:Hi all, just downloaded the new beta and looked particular to the Setpoint functionality. Looks a lot better! But is not completely working as expected.. [SMILING FACE WITH OPEN MOUTH AND COLD SWEAT] I have created a screencast of it. It looks like the *.5 temperatures are not working fine and the animation at low temperatures is not looking very nice (not smooth).
Thanks for the screen cast.
Yes, there is some rounding issue when the temp has half a degree.
Still searching and trying to figure out why this is. :?
galadril
Domoticz version: latest
Post by galadril »
We're doing great in Italy!
Can someone maybe translate the app to Italian? Or do you know someone that could do it? :roll:
https://crowdin.com/project/domoticz-for-android/it#
LouiS22
Post by LouiS22 »
Hi folks,
With the latest beta, I've lost Humidity on Temperature tab, instead of that all of my Temp sensors have Setpoint. What's more strange: there are a few Favourite temp/hum sensors placed on Dashboard, they now have Temp and hum, dew point, another temp (with round values (for ex 21C)), and humidity with text format (for ex wet).
Scoobydoo
Post by Scoobydoo »
Had an issue with the app taking ages to load up last night. A good 20 seconds or so.
I noticed that the forum was down for a while last night too..is the app linked to.the forum.somehow? It seems like because the forum was off line then the app was timing out?
It's fine again this morning as the forum is back online.
Maybe this check could be removed so the app doesn't do this?
Apart from that it's a great app.
