Security Panel
Het-Licht
Security Panel
Anybody an ida how to get the security panel in the switches tab ? I found the the security panel should be in the device list but I can't find it the so it's impossible to ad it to switches. Anybody an idea ?
geronimobb
Re: Security Panel
I'm not sure, but i think after if you use it once from -> setup -> more options -> security panel, it should appear also in your device list.
Grtz.
Grtz.
jin
Re: Security Panel
Do you have configured a PIN code from Setup menu?Het-Licht wrote:Anybody an ida how to get the security panel in the switches tab ? I found the the security panel should be in the device list but I can't find it the so it's impossible to ad it to switches. Anybody an idea ?
SecPanel automatically appears into Switches tab when you setup a PIN code.
Het-Licht
Re: Security Panel
Got it, appeared after i set the pin code! Thanks!
- groetg
- Domoticz version: V2.4025
Re: Security Panel
Also with the pin code set it won't Work on my banana pi.
What could be the problem?
Master: RPI Model 2B
Sub 1: RPI Model 2B
RFX transmitter/receiver 433 Mhz
13 KAKU units (3 window sensors, 1 door sensor, 7 light switches, 1 dusk sensor, 1 motion sensor)
4 IP cam
Meteostick
OTGW
P1 cable
Davis Vantage Pro weatherstation (incl. solar/UV)
Sub 1: RPI Model 2B
4 IP cam
Meteostick
OTGW
P1 cable
- groetg
Re: Security Panel
When i visited http://<IP-domoticz>:8080/secpanel/index.html I tried to arm the panel, after that the switch appeared.
Sub 1: RPI Model 2B
4 IP cam
Meteostick
OTGW
P1 cable
Sub 1: RPI Model 2B
4 IP cam
Meteostick
OTGW
P1 cable
- groetg
Re: Security Panel
had same problem. Solution no user and password than it works well.
Sub 1: RPI Model 2B
4 IP cam
Meteostick
OTGW
P1 cable
Sub 1: RPI Model 2B
4 IP cam
Meteostick
OTGW
P1 cable
elgarne
Re: Security Panel
I can see a security panel in my devices after adding a pin code, deleting username/password, and arming home/away.
Adding this device to the map does not allow me to change the status nor to access the panel to enter the pin code. When I press the button, I have the following message:
which means
How do you proceed please? Thanks.
PS: I'm using V3.4855
Erreur d'envoi de la commande à l’interrupteur, vérifiez le dispositif/matériel !which means
error sending command to the switch, please verify device/hardwarePS: I'm using V3.4855
TheTambu
- Domoticz version: 3.8153
Re: Security Panel
with version 3.8153 the Security Panel can be found in the Setup->Device list as "Domoticz Security Panel", and needs to be manually added to the used devices. After it can be found in the Swithces panel and eventually added to the Dashboard.
quilae
Re: Security Panel
Just for information: To make this work it is necessary to have Domoticz accept new hardware devices. It took me 15 minutes before I realized my mistake.
B.T.W.: I think the timers function is wrong here. If I set a timer I only have the option to set it on or off. So what's the on state here? Is it armed home or armed away. I didn't try this because I use this switch in a different way.
