How to use CGI
Marq
How to use CGI
Post by Marq »
I have a device (camera Foscam FI9821w v2 to be exact), from which the status can be queried by executing a CGI command:
http://192.168.1.2/cgi-bin/CGIProxy.fcgi&usr=admin&pwd=123&cmd=ABC
a webpage is opened which shows the status, eg.:
<CGI_Result>
     <result>0</result>
     <isDHCP>1</isDHCP>
     <ip>192.168.1.8</ip>
     <gate>0.0.0.0</gate>
     <mask>255.255.255.0</mask>
</CGI_Result>
I am looking for a way to use this info in LUA.
Anyone know how to do it ?
A short example / guide would be helpfull.
Thanks, Mark
cul8r
Re: How to use CGI
Post by cul8r »
The only way in LUA that I know is to go via a file (but I am not a LUA expert):
os.execute('curl "http://192.168.1.2/cgi . . . (your cgi command) . . ." > /home/pi/xxx.txt')
then in LUA open the file and read what you need.
/C
nayr
Domoticz version: github
Re: How to use CGI
Post by nayr »
what exactly in the response do you want, none of that information looks usefull..
you can issue http get requests blindly without parsing the response, there are a few ways to do it.. OpenURL in lua is one way, blocky has the same function and switches can also make requests to url's.
