Which hardwares should I buy?
sonixax
Post by sonixax »
I have a plan to make my own SmartHome!
and want to use these brands :
InterTechno
HomeMatic
and some FS20 Hardwares!
So I need to know which gateways should I buy to work with Domoticz ?
Thakns a lot :)
LouiS22
Re: Which hardwares should I buy?
Post by LouiS22 »
sonixax wrote:Hi,
InterTechno
HomeMatic
Thakns a lot :)
My advice and experience: forget the two above: both using a special "gateway", which handles the communications with their own device. It would be hard to add new, 3rd party devices because of this. So I suggest you the z-wave way: a USB stick costs less than a gateway, and you can find many z-wave devices. They are not cheap, though.
stlaha2007
Post by stlaha2007 »
Have no experience with Zwave. Have Philips Hue bridge and RFXTrx433e with KlikAanKlikUit (though also known as LightwaveRF or CoCu).
FSxx is also known as HomeEasy stuff in Holland. Is 433 Mhz frequency.
KlikAanKlikUit is working great, biggest disadvantage to Zwave it doesn't reports its current status back. So if thats needed jump into Zwave with Fibaro named devices. Else Rfxtrx433e ttansciever gateway (around 110euro) is needed.
Grtz,
Stephan
