Sky HD Box Test
sijones
Domoticz version: Git
Sky HD Box Test
Post by sijones »
As it seems some people would like Sky support am having a look at it - am not promising anything as i don't own a sky box, am researching and trialing things.
So can someone try this command on a linux box - make sure you have netcat installed
echo '4100002240' | nc -w 1 SkyIPAddress 49160
and let me know the result.
Westcott
Re: Sky HD Box Test
Post by Westcott »
I got this -
nc: getaddrinfo: Name or service not known
suridge
Re: Sky HD Box Test
Post by suridge »
First post here, hope this is helpful...
$ echo '4100002240' | nc -w 1 192.168.0.2 49160
SKY 000.001
$ nc -w 1 192.168.0.2 49160
SKY 000.001
sijones
Re: Sky HD Box Test
Post by sijones »
Westcott wrote:I got this -
Apologies, I should have said you need to change SkyIPAddress to the IP address of the box.
sijones
Re: Sky HD Box Test
Post by sijones »
suridge wrote:First post here, hope this is helpful...
SKY 000.001
SKY 000.001
Did the box respond / do anything, that command should be the power toggle, so switch to standby and out of standby?
blackdog65
Re: Sky HD Box Test
Post by blackdog65 »
I get this
$ echo '4100002240' | nc -w 1 192.168.1.75 49160
SKY 000.001
I tried with the sky box on and on standby, but nothing happened. Hope that still helps in some way.
Good luck :D
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
C4rtm4N
Re: Sky HD Box Test
Post by C4rtm4N »
Tried on 2 Sky boxes with both the old & the current EPG & they return the same as Suridge, neither coming out of standby.
Reply is identical whether the box is on or if it's off.
Westcott
Re: Sky HD Box Test
Post by Westcott »
No - my fault for not putting my IP addr in :oops:
Now I get standby and on -
SKY 000.001
As Blackdog65 reported, nothing changed on the box itself.
Attempting to ping the box, the ping command hangs (yes, really!)
Added the box's IP to Domoticz to the 'System alive checker', it does not change status
sijones
Re: Sky HD Box Test
Post by sijones »
Cheers for testing, I'll have a another look and come back to you.
sijones
Re: Sky HD Box Test
Post by sijones »
ok, little update.
I have the way to toggle the box power, i need to put it in to domoticz but it's not going to be quite a straightforward implementation as it needs 2 different ways of talking to the box, one for power and the other to test the status for if the box is on or off.
So I will leave this open to you who want this, either i need someone to forward ports on their router so i can test against it - this can be locked to only allow my static ip's so shouldn't be too risky.
or someone with a spare box or you club together to buy a cheap second hand one sent to me and i'll put something together on that.
Note that I can't promise a date of completion, i do this in my spare time and that varies week to week.
Let me know what you think.
C4rtm4N
Re: Sky HD Box Test
Post by C4rtm4N »
As discussed I can open ports temporarily but I'm away on business for most of the next 3 weeks so it needs to wait until after then. Hopefully one of the others who are interested in this can help before then.
How are you thinking about detecting whether it's on?
sijones
Re: Sky HD Box Test
Post by sijones »
There's a function call over dnla interface that may give away that the box is on - yet to test.
Although to be honest by the lack of response I may not do this as it's not seemly wanted!
sijones
Re: Sky HD Box Test
Post by sijones »
Here's a linux app that will toggle the box power:
#include <sys/socket.h>
#include <sys/types.h>
#include <netinet/in.h>
#include <netdb.h>
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <unistd.h>
#include <errno.h>
#include <arpa/inet.h>
int main(int argc, char *argv[])
  int sockfd = 0,nin = 0,nout = 0,l = 12;
  char recvBuff[32];
  char sendBuff[9] = {4,1,0,0,0,0,224,0};
  struct sockaddr_in serv_addr;
  if(argc < 2)
      printf("\n Usage %s Sky box IP address\n", argv[0]);
      return 0;
  memset(recvBuff, '0' ,sizeof(recvBuff));
  if((sockfd = socket(AF_INET, SOCK_STREAM, 0))< 0)
      printf("\n Error : Could not create socket \n");
      return 1;
  serv_addr.sin_family = AF_INET;
  serv_addr.sin_port = htons(49160);
  serv_addr.sin_addr.s_addr = inet_addr(argv[1]);
  if(connect(sockfd, (struct sockaddr *)&serv_addr, sizeof(serv_addr))<0)
      printf("\n Error : Connect Failed \n");
      return 1;
  while (1)
    nin = read(sockfd, recvBuff, 31);
    if( nin < 0)
        printf("\n Read Error \n");
    if (nin < 24)
      nout = write(sockfd, recvBuff, l);
      if( nout < 0)
          printf("\n Write Error \n");
      l = 1;
      nout = write(sockfd, sendBuff, 8);
      if( nout < 0)
      sendBuff[1] = 0;
      if( nout < 0)
      close(sockfd);
      return 0;
blackdog65
Re: Sky HD Box Test
sijones wrote:Although to be honest by the lack of response I may not do this as it's not seemly wanted!
I happy to help (been busy with my E3Q Max! Heating Control), but I'm not sure what you want to achieve.
Obviously an off command has uses (though mine has an auto sleep function) but what else is possible?
Sean
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
C4rtm4N
Re: Sky HD Box Test
Post by C4rtm4N »
Blackdog, is 'on' not the aim as if people have it connected to a supported TV via HDMI it will turn the TV on. Live pause on a doorbell ringing is also lee's aim.
C4rtm4N
Re: Sky HD Box Test
Post by C4rtm4N »
Thanks for the code @sijones - I will try it later if I have time before I leave
Marci
Domoticz version: 3.8153
Re: Sky HD Box Test
Post by Marci »
Use app above to toggle power, use any of the current Node-based libraries to provide a http api for the rest...?
The notable two are...
https://github.com/dalhundal/sky-plus-h ... plus-hd.js
https://github.com/mwrf/skyplus.js
The former, if memory serves provides a box-status request also.
Should simplify a pause script down to triggering a switch in domoticz which fires the relevant http request over to localhost:5555 or similar.
Extended Domoticz homebridge-plugin for latest Homebridge - adds temp/humidity/pressure sensors, power consumption sensors, DarkSkies virtual weather station support, YouLess Meter support, general % usage support & switch/lamp status checking!
blackdog65
Re: Sky HD Box Test
C4rtm4N wrote: Live pause on a doorbell ringing is also lee's aim.
Yup, sounds useful. If the communication is two-way then lighting control (like kodi) would be super sexy!
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
C4rtm4N
Re: Sky HD Box Test
Post by C4rtm4N »
Many thanks @sijones - code is working well :)
@Marci - I never could get dalhundal's code to work although it looks as though he does now have a more simple remote app available that can't get the sky box's state
sijones
Re: Sky HD Box Test
Post by sijones »
C4rtm4N wrote:Many thanks @sijones - code is working well :)
Code was in the public domain so no need to thank me, was pointed to me by Dal, the developer of the NodeJS stuff.
Possibly if enough people want the functions I'll integrate something but have had to look at something else at the minute that we need more importantly.
Cheers sijones
