Intertek 750061455010X10 Wireless Switch Unit
simondelion
Post by simondelion »
I bought a set Intertek 750061455010X10 Wireless Switch Unit in the local Action store.
I used the RFXmngr manager to identify the sending signals of the remote and received the following information placed below.
When I try to send a command to a switch using these variabels nothing happens.
However it works with a older version Eurodomest 972080 that I bought earlier.
Does anyone can help me to get the Intertek set working?
Packettype = Lighting2
subtype = AC
Sequence nbr = 206
ID = 029EC02 decimal:2747394
Unit = 1
Command = On
Signal level = 7 -64dBi
subtype = HomeEasy EU
Sequence nbr = 207
ID = 001EE8A decimal:126602
Unit = 1
Command = On
Signal level = 6 -72dBi
Packettype = Lighting1
subtype = ARC
Sequence nbr = 208
housecode = I
unitcode = 9
Command = On
Talos
Re: Intertek 750061455010X10 Wireless Switch Unit
Post by Talos »
I bought the same switches at Action today. I can't get them to work with my RFXtrx433E, although I read that RFlink supports them so it think should be possible to get them to work. Anyone has an idea?
bucky
Post by bucky »
I did a first learning on type lighting4 only just learning, then switch over to ACR. and save under hardware.
Talos
Post by Talos »
Hmm, could you elaborate a bit? I'm quite new at all of this.
bucky
Post by bucky »
go to hardware and select lighting 4 .
go to switches en start learning
before using go back to hardware and unselect lighting 4 select ACR.
This worked for me.
regards
Talos
Post by Talos »
Did you first pair the remote with the switch and then start learning? Or did you put the switch in pairing mode and then start the learning process before pairing?
I can see the status of the light changing in Domoticz when I push a button on the remote but when I click in Domoticz nothing happens.
bucky
Post by bucky »
I first paired the switch & the remote and than Domoticz in learning mode and switch on and then in learing mode switch of.
it does not togle
ThinkPad
Post by ThinkPad »
Try creating a switch using the 'ARC' protocol and a random ID. Then put the unit in learning mode and click the 'Test' button in the popup that opened when you are creating the switch.
The older Eurodomest set i had from Action worked fine that way. I couldn't get the included remote to work, but i don't use those remotes anyway.
Frankm
Post by Frankm »
got exactly the same problem over here, Kaku is working, howerver the intertek switches from the action are not recieving data from domoticz, however, domotic recieves the info from the remotes.
Users browsing this forum: BarryT and 1 guest
