Pilot: Home Automation Control (iOS app)
Bikey
Domoticz version: 2020.x
Re: Pilot: Home Automation Control (iOS app)
Post by Bikey »
Great! When will 1.7 be released?
patoo77
Post by patoo77 »
Bikey wrote:Great! When will 1.7 be released?
Beta this week, release on the AS when the beta is stable enough :P
Bikey
Post by Bikey »
To add to my earlier post: I see in the logs that the Pilot App does try to connect to my Domoticz server (with the login errors), even if I have closed the App and removed it from the background. That seems to my as being undesirable behavior, why is that?
(I have disabled the notifications in Pilot)
patoo77
Post by patoo77 »
Bikey wrote:To add to my earlier post: I see in the logs that the Pilot App does try to connect to my Domoticz server (with the login errors), even if I have closed the App and removed it from the background. That seems to my as being undesirable behavior, why is that?
If you activate location services, this can obviously happen even if the app is closed/killed.
Otherwise the app can't do anything in the background.
Bikey
Post by Bikey »
patoo77 wrote: If you activate location services, this can obviously happen even if the app is closed/killed.
Sure, I agree that if a switch must be triggered based on the location, the App must activate a JSON-command to Domoticz. However if no triggers are present there should be no need for Pilot to poll Domoticz in the background, is that correct?
Besides that, I have not not even activated location services in Pilot and also have not activated push-services. I even disabled background refresh for Pilot in the iOS settings, but still I get login messages in the Domoticz log :?:
** EDIT ** I may have found the reason: I was using the Pilot widget, I guess that is doing the polling if you open the iPhone homescreen?
Have removed the widget, see what happens.
deejc
Domoticz version: 3.5641
Post by deejc »
I have recently setup my domoticz install to use the secure nginx reverse proxy,including SSO, But i am unable to setup pilot to use the internet accessible url, any ideas why it doesnt work ?
i am using these settings:
Address = url.domo.com
port 443
SSL = on
Self Signed = on
requires login = on
username = username from cert and also pasted in domo settings
password = tried both the password i used to have setup and the email address in the cert.
error message reads :
error trying to connect to the server, please make sure your server settings are correct.
I can send a URL using UN:PW@IP/json.htm .... from my phone and it switches on/off.
Domoticz 3.5641 on RPI (Raspbian GNU/Linux 8)
pepijn
Post by pepijn »
deejc wrote:I have recently setup my domoticz install to use the secure nginx reverse proxy,including SSO, But i am unable to setup pilot to use the internet accessible url, any ideas why it doesnt work ?
port 443
SSL = on
Self Signed = on
requires login = on
The app does not support client certificate authentication. The browser on your device sends the client certificate to nginx when needed. This is not available in the app.
Kenedy
Post by Kenedy »
you have explained the topic very well.Great Job
Graduated from Soran University with First Class Degree with Honours in Computer Science.
deejc
Post by deejc »
so this wont be a feature of the app ? to use the client certificate ?
I assumed form the SSL switch and Self Signed Cert switch this was a feature...the reason i ask is that i believe i saw a post in another thread that mentions the pilot app "Doing Domoticz authentication properly" so i wonder what properly means if not via certificate ?
cheers
pepijn
Post by pepijn »
deejc wrote:so this wont be a feature of the app ? to use the client certificate ?
cheers
I'am not the developer of this app, maybe he will implement x509 but it's also not native supported by Domoticz.
The option Self Signed Certificate allows you to use a server certificate that is signed by your own CA. These certificates are generally marked invalid because they are not issued by a trusted CA (like Symantec)
patoo77
Post by patoo77 »
That should be the notification center widget, yup :) please let me know if it gets better now!
cheers
Thanks for the reply as I was not sure myself wether this should actually work or not. I think you are right though, client certificate can't work at the moment.
Soon you will be able to use the reverse proxy server my.domoticz.com directly within Pilot. Lots of stuff to be done on the mydomoticz service first, but that would definitely be the easiest way to connnect to your Domoticz server from the outside, and securely. ;)
P
deejc
Post by deejc »
i use that service as well, if the pilot app worked through that app i would turn off the reverse proxy and us the my.domoticz site exclusively
thanks, i will keep an eye on this thread for info.
Dynamic
Post by Dynamic »
Running 1.7 beta now. Interface is getting better and better. I really like the circles.
Got one issue: when trying to view a graph, the first 1-2 times it does nothing at all. After that, I can view the graph. Can it be a caching-problem?
Steven84
Post by Steven84 »
On iphone 5s graphs don't work. The swipe function works really good
Verzonden vanaf mijn iPhone met behulp van Tapatalk
patoo77
Post by patoo77 »
deejc wrote:i use that service as well, if the pilot app worked through that app i would turn off the reverse proxy and us the my.domoticz site exclusively
I talked about it with chimit some time ago. MyDomoticz is still in alpha, they are focusing on making it work flawlessly. Then they will add support for 3rd party app login.
When that's ready, Pilot will be too ;) it's actually one of the reasons why I added multi-server, I needed it to make Pilot totally compatible with the mydomoticz features. :lol: lots of work involved, but worth it ^^
Lots of good stuff incoming, gotta be patient though!
Steven84 wrote:On iphone 5s graphs don't work. The swipe function works really good
Can you be a bit more specific? Send me a screenshot, and the kind of device you're trying to see the graph for ;)
Dynamic wrote:Running 1.7 beta now. Interface is getting better and better. I really like the circles.
Well that's weird!
Do you get that on *every* device?
Steven84
Post by Steven84 »
Edit: Graphs do work but really hard to open.
Steven84
Post by Steven84 »
Alarm panel shows status not correctly. Image
deejc
Post by deejc »
patoo77 wrote: Lots of good stuff incoming, gotta be patient though!
yeah i see a lot of good things coming, i have been holding off purchasing the new vera plus if i can get domoticz to do the things my old vera edge used to do.
i am just waiting on decent reverse proxy for security and geofencing and sonos support :roll:
patoo77
Post by patoo77 »
Well you already got geofencing with Pilot! :P
I am also working on iBeacon support to make it even better.
Steven84 wrote:Alarm panel shows status not correctly.[/img]
I don't see what the problem is :lol: :lol: :lol:
I think I forgot to test the display on iPhone 5S... :lol:
Steven84
Post by Steven84 »
I will immediately demand my boss to get me iphone6
