New Multisensor 6 seems to miss functionality
Hardyhardest
Re: New Multisensor 6 seems to miss functionality
Post by Hardyhardest »
Has anyone got the calibrating working?
I still can't calibrate humidity via Domoticz so last post is still not a fix for me.
Holland
Domoticz version: Beta Ch
Post by Holland »
Have you deleted the xml file. To be found in the domoticz/Condig map. E.g zwcfg_0xe621e9ec.xml
yellington
Post by yellington »
I've made a simply step-by-step guide for adding and configuring the Aeon Labs Multisensor 6.
http://www.yellington.com/adding-and-co ... -domoticz/
Hardyhardest
Thank you yellington!
I noticed that it returns correct value now but in settings it still shows 255. No biggie but if now for some reason you still need to adjust reading you need to subtract from new measured value.
H
micbou
Post by micbou »
I cant seem to find how to set the interval of the Multisensor sending Lux data to domoticz. I want my lights to turn on when the amount of light in my living room gets under a x-amount of Lux and the lights to turn off when there hasnt been any motion in the living room for 15 minutes.
loyske
Post by loyske »
I've set parameter 101 to 224 and parameter 111 to 60 seconds. This way, my lux is reported every minute.
I have tried with selective reporting, but i couldn't get it to work like i wanted.
