Telegram issue
Michael85
Telegram issue
Post by Michael85 »
I've some problems with setting up Telegram.
I followed the wiki instructions, but I'm stuck at the Domoticz set up.
What did I do?
I placed the URL en replaced #TO with my Telegram ID. (the URL is working if I open it and I recieve a message)
So my URL is: https://api.telegram.org/bot112233344:A ... t=#MESSAGE
On the left side I selected the smart meter.
Target type: Global variable
Device name: Elektra
Value to send: Usage current
Target variable:
Include unit: yes
Link active: yes
Which value do I need to use in the target variable field?
I hope someone can help me with this :)
simonrg
Domoticz version: 3.8807
Re: Telegram issue
Post by simonrg »
Not sure about the Target Variable field, but your post seems to be mixing up two different sets of settings.
First you need to go to the Setup / Settings / Notifications - enable Custom HTTP / Action - put your Telegram ID into the To field, then fill the URL / Action field with:
Press the Test button to see if it all works.
Second go to your device and set a notification choosing HTTP as the communication method.
Raspberry Pi 2 B - 2A@5V PSU - Raspbian + Domoticz + RFXtrx(89), LightwaveRF House(dimmers, sockets, wireless/mood switches), Owl CM113, 4 LaCross Temp / Humidity Sensors, 4 Siemens PIR, Smappee, Solaredge, ESP8266
Michael85
Re: Telegram issue
Post by Michael85 »
How stupid of me.... I was looking at the data push -> HTTP.
It's working now, thanks for your help!
