I am new to domoticz, working fine by the way. I have a simple Windows based setup in combination with AEON Labs Gen5 controller (USB).
Now I am thinking of hooking up my smart meter , but do not have options to cross the distance from downstairs hallway to upstairs attic pc.
I would have to buy a Raspberry (or similar setup) to run domoticz on that and attach p1 converter cable to the usb interface. However is it also possible to acquire a USB ethernet hub that i can place near the smart meter and router and attach a p1 converter cable to that? Would Domoticz on my pc be able to detect the attached converter cable through remote shared USB port? IF not than I will stick to another plan.
Link to sample USB device:
http://www.bb-elec.com/Products/USB-Con ... t-Hub.aspx
Thanks in advance!
Gert
Domoticz compatible with USB network servers?
- Domoticz version: 2022.2
Re: Domoticz compatible with USB network servers?
If it works from windows, you could always create a script that reads the values and puts them in Domoticz via a json call
- Domoticz version: 2.4608
@jannl, do have a script that does that, or is there a topic with an example?
RPi Model 2: Domoticz Server (Beta)
RPi Model B+: Smart Meter Slave (Stable)
Particle Photon (2x): Prototyping, Controlling LEDS and gathering Sensor data for Domoticz
Arduino Uno R3: with CC2500 Shield for Philips LivingColor Lights 1st Gen.
not that I know of, I do not do that my self.
You also can setup the raspberry as a Domoticz slave
@Jannl, thanks, did the trick! https://www.domoticz.com/wiki/Setting_up_Device_sharing
