Hello.
I installed my Owl Micro+ (Cm180) today, and I seem to get way too high power usage (watts).
I have a three phase input, so I use all three clamps around each phase. I then adjusted the Owl to read the voltage as 130V (each phase is ~130V, but it's a 230V supply)
The Owl display is now quite accurate, showing the instant power usage and my accumulated kWh..
But even though I correct the voltage under settings Domoticz shows alot more instant usage than the Owl display, over double it. (Owl shows 4.8 kW, Domoticz shows 8.8 kW)
The CM180 is registered under devices as Type: General and SubType: kWh. It doesn't say anything about CM180, so does this mean the Settings-page doesn't affect my device? (Since CM113/180 is specifically mentioned there)
How can I make Domoticz read the same as the Owl display?
Domoticz version 2.4337
OWL showing too high usage
