Widgets for evohome is still a WIP (work in progress).mschut wrote:First: great app, keep up the good work.
Evohome support is one of my main interests, happy to see it's included. Some feedback.
Main controller is integrated now. However, the widget shows a different button. On/off instead of set.
As mentioned before, would really like to control the individual thermostats as well. Happy to help testing.
- RoadXY
- Domoticz version: 2.2331
Re: Domoticz app 2.0
- RoadXY
Could you provide a screenshot please?Eloque wrote:Recently tried the app, but at this point it is not working for me, this is because of one thing, SmartWares radiator valves.
I've installed SmartWare valves throughout my house, in Domoticz they show as both a switch and a utility. In the web interface I can set the valves to any temperature, but in the app they can't be set in the "Other" tab, just seen. I can't set them.
- RoadXY
You may thank @galadril for this.maluko wrote:Thanks for the good work
- RoadXY
Thanks for the extended info provided! Wish everyone did thisSiewert308SW wrote:Thx for the great app.
But have a issue when i want to look into my energy logs which are measured by a YouLess.
When i hit the log (day,Month,Year) i see the following error and can't look into the logs.
All other logs are working fine only the YouLess doesn't work...
App: Domoticz 0.1.222 Premium
System: Domoticz [beta] 2.4298
Raspberry 2b
Phone: HTC One M9 - Lollipop Sense 7
Could you long press the debug text and post here?
- RoadXY
Do I get this right that the whole app crashes because you have SmartWares radiator valves?Eloque wrote:Recently tried the app, but at this point it is not working for me, this is because of one thing, SmartWares radiator valves.
- RoadXY
Yes but it's not high on our list since we have a lot to do for supporting all devices and solving bugsJoshDinsdale wrote:Are you looking at tasker integration? Would be nice to be able tie it in for voice controls via AutoVoice.
Thanks.
- Siewert308SW
- Domoticz version: Stable
ThxRoadXY wrote:Thanks for the extended info provided! Wish everyone did thisSiewert308SW wrote:Thx for the great app.
Raspberry 2b
Sure...
Link below is for pastbin where i put the debug text.
Tried to get it right but somehow the text doesn't contain any hard enters...
Hope it works for you guys.
http://pastebin.com/kMDyswx1
Setup:
- RPi4 - Domo Stable / Aeotec Z-stick7 / PiHole Unbound Gemini
- RPi4 - PiHole / PiVPN Unbound Gemini
- Synology DS923+ / DS218j
- P1 Gas/Power, SmartGateway watermeter
- Fibaro switches, contacts, plugs, smoke/Co2 ect
- rootfs @ USB HDD
- rootfs @ USB HDD
I'am not a premium user because the app doesn't work for me right now. Does the beta fix the startup bug?RoadXY wrote:We received some crash reports.ceedebee wrote:Still crashes at start-up on my tablet and phone. What is wrong with my setup?
We'll be updating soon. Are you a Premium user? In beta testing channel?
- RoadXY
It does contain some fixes regarding crashes on startup.ceedebee wrote:I'am not a premium user because the app doesn't work for me right now. Does the beta fix the startup bug?RoadXY wrote:We received some crash reports.ceedebee wrote:Still crashes at start-up on my tablet and phone. What is wrong with my setup?
If this is solved for you.
Did the app ever work?
Do you know how to get the logcat?
You'd got to have ADB installed:
http://lifehacker.com/the-easiest-way-t ... 1586992378
Tutorial on how to logcat with ADB here:
http://forum.xda-developers.com/showthr ... ?t=1726238
- RoadXY
Hmm, I don't see any error in there.Siewert308SW wrote:ThxRoadXY wrote:Thanks for the extended info provided! Wish everyone did thisSiewert308SW wrote:Thx for the great app.
Raspberry 2b
Sure...
Could I have access to your server?
Send me a PM with your details if your oke with me having read only access to your server.
- Siewert308SW
Let me know when your ready and i will forward the necessary ports...
Setup:
- rootfs @ USB HDD
- rootfs @ USB HDD
The app worked two updates ago. I think it has something to do with the implementation of the security panel. The crashreport states: linenumber 583 in module setSecurityPanelSwitchRowData.RoadXY wrote: It does contain some fixes regarding crashes on startup.
- RoadXY
I need the full crash, please.ceedebee wrote:The app worked two updates ago. I think it has something to do with the implementation of the security panel. The crashreport states: linenumber 583 in module setSecurityPanelSwitchRowData.
How can I send you the crash report? The ADB tool is a bit to difficult for me I'm afraid.
- RoadXY
I could connect to your server and test?ceedebee wrote:How can I send you the crash report? The ADB tool is a bit to difficult for me I'm afraid.
Create a view only account and I'll test.
Send me a PM with the (IP) address, port, username and password if you don't mind.
I'am sorry VPN connect only. Does sending the report to google helps you?
- RoadXY
Yes, it does.
Report is sended.
- Thijsvr
- Domoticz version: 2.4075
Hi, just wanted to reply that I've been using the premium version of the app for some time now. Very happy with it so far. I have noticed two things though:
- Using widgets (well actually just one) consumes a lot of battery. 10 ~ 15% on a full day on a Galaxy S6.
- Android Wear app doesn't load on my Moto360 Gen1. It only opens the loading screen which cuts out after a few seconds.
Are you planning supporting Tablets (2 or 3 colums) in the future?
I saw a commit concerning a tablet-view (https://github.com/domoticz/domoticz-an ... b530727afa), is it still on your list?
