Particle Photon Temperature Logger
daandamhuis
Domoticz version: 2.4608
Post by daandamhuis »
Hi All,
I don't know if this is the right place, but i managed to create a Particle Photon temperature logger with a DHT22 sensor. If someone has any suggestions to the code, please give them! :D
#include "application.h"
#include "PietteTech_DHT/PietteTech_DHT.h"
// system defines
#define DHTTYPE                 DHT22 // Sensor type DHT11/21/22/AM2301/AM2302
#define DHTPIN                  3     // Digital pin for communications
#define DHT_SAMPLE_INTERVAL     10000  // Sample every minute
#define LUXPIN                  A1    // LDR Pin
#define READ_INTERVAL           10000
//Setup DHT Sensor reading
void dht_wrapper();
PietteTech_DHT DHT(DHTPIN, DHTTYPE, dht_wrapper);
//Setup Global Variables
unsigned int DHTnextSampleTime; // Next time we want to start sample
bool bDHTstarted;		        // flag to indicate we started acquisition
int n;                          // counter
int lux;
char VERSION[64] = "1.0";
char resultstr[64]; //String to store the sensor data
TCPClient client;
IPAddress remoteIP(192,168,178,196);
void setup() {
    DHTnextSampleTime = 0;  // Start the first sample immediately
void dht_wrapper() {
    DHT.isrCallback();
void loop() {
    if (millis() > DHTnextSampleTime) {
        if (!bDHTstarted) {		// start the sample
            DHT.acquire();
            bDHTstarted = true;
        if (!DHT.acquiring()) {		// has sample completed?
            char tempInChar[32];
            char humidInChar[32];
            //Calculate Temperature
            float temp = (float)DHT.getCelsius();
            int temp1 = (temp - (int)temp) * 100;
            //Calculate Humidity
            float humid = (float)DHT.getHumidity();
            int humid1 = (humid - (int)humid) * 100;
            //Calculate Light
            float light_measurement = analogRead(LUXPIN);
            lux = (int)(light_measurement/4096*100);
            //Put Variables in Char
            sprintf(tempInChar,"%0d.%d", (int)temp, temp1);
            sprintf(humidInChar,"%0d.%d", (int)humid, humid1);
            if (client.connect(remoteIP, 8080)) {
                Particle.publish("Connection Domoticz", "Success", 60, PRIVATE);
                client.println("GET /json.htm?type=command&param=udevice&idx=1&nvalue=0&svalue=" + String(temp) + ";" + String(humid) + ";1 HTTP/1.1");
                client.println("Host: "+ remoteIP);
                client.println("Authorization: Basic <Authentication..>");
                client.println("Connection: close");
                client.println();
            n++;  // increment counter
            bDHTstarted = false;  // reset the sample flag so we can take another
            DHTnextSampleTime = millis() + DHT_SAMPLE_INTERVAL;  // set the time for next sample
RPi Model 2: Domoticz Server (Beta)
RPi Model B+: Smart Meter Slave (Stable)
Particle Photon (2x): Prototyping, Controlling LEDS and gathering Sensor data for Domoticz
Arduino Uno R3: with CC2500 Shield for Philips LivingColor Lights 1st Gen.
StanHD
Re: Particle Photon Temperature Logger
Post by StanHD »
Wow ......... a what? 8-)
Python:- Broadlink RM2, Sonos
daandamhuis
A Particle Photon is a small development board with integrated wifi. It's pretty easy to setup and I find it useful for sensor data.
alexsh1
Domoticz version: v3.8975
Post by alexsh1 »
I am using it too with several sensors. However, several issues:
1) It may occasionally go out of sync with wifi
2) it is expensive (£21 is the cheapest here in the UK) though has got Wifi integrated but compare with other wifi boards (£5-8) is just too overpriced.
3) the firmware has to be updated regularly - not a problem but just an extra.
4) Not extremely low power friendly - wifi consumes a lot of power. For me this is not an issue as I am powering it from my iPhone charger.
5) I do not like DHT22 - I think using a low powered Si7021 via i2c is way much better and more precise.
Right now, I am looking at Electron (3G) to connect it to RPi and Domoticz - this may be an interesting way to have 3G backup connection or restart internet router / Domoticz if the main interenet connection fails though again expensive (priced $49 in the US).
