Hye,
Does somebody knows if i can retrieve the level of a dummy dimmable switch to inject into ACTION ON URL , when i move the slider of the switch, this command is executed :
/cuisine.php?code=On , and i want to add the percent level to my URL , something like that : &level=[level] ?!
Is there some existing variable at the execution time that can be used ?? thanks for advice
Just for context : a moteino is connected to raspberry serial line , and IR LED send NEC code to a led stripe
Action On parameter dimmer level
jautem
- Domoticz version: 2.3530
raspberry cam - moteino rfm69 - Zwave Stick - IR - 433 transceiver
- nayr
- Domoticz version: github
Re: Action On parameter dimmer level
try a script_device_*.lua script like this:
if (otherdevices['My Device'] == 'On') then
commandArray['OpenURL']="127.0.0.1/cuisine.php?code=On&level=" .. otherdevices_svalues["My Device"]
return commandArrayDebian Jessie: CuBox-i4 (Primary) w/Static Routed IP and x509 / BeagleBone with OpenSprinkler / BeagleBone Planted Aquarium / 3x Raspbery Pi2b GPIO Slaves
jautem
thanks to you for answer , it's a good alternative if gui don't permit de retrieve level value.
But the property level is empty , in gui i got " Set Level: 53 %, Level: 53 %" , but in otherdevices_svalues['Cuisine_Led'] , printed in debug i got zero ??!!!
Do you have an idea ?
jautem
This is solved now !! , here the final script working fine :
if (devicechanged['Cuisine_Led'] ) then
if (otherdevices['Cuisine_Led'] == 'Set Level') then
commandArray['OpenURL']="127.0.0.1/cuisine.php?code=Dim&level=" .. otherdevices_svalues['Cuisine_Led']
print('Level : '..tonumber(otherdevices_svalues['Cuisine_Led']))
The difference is to test equality with "Set Level" string , with this the array other devices_svalues handle the right level
Thanks again .
Thanks again .
deennoo
Great ! Thanks for this.
Got same needed using Milight.
Level can't be handel on lua.
I plan to use a IR remote to drive the TV corner.
IR gateway is made with a rpi lirc and irexec.
Actually can drive scene, and turn on and off TV corner.
Got 2 buttons who are plan to drive milight dimmer one for up one for down.
Each button hit have to set dimmer +5 or -5% from thé actual level.
Off course, if light is off first press on UP button have to set light on and to 5%.
Will try to use your script.
http://domo-attitude.fr
Anybody can help me with this (Dummy Dimmer)?
script_device_VU.lua:
In log:
2017-03-23 22:07:13.005 User: Admin initiated a switch command (37/VU/Set Level)
and no Level:..... what is in the script. So it's not working. Any ideas?
if (devicechanged['VU'] ) then
if (otherdevices['VU'] == 'Set Level') then
commandArray['OpenURL']="http://192.168.1.99/web/vol?set=" .. otherdevices_svalues['VU']
print('Level : '..tonumber(otherdevices_svalues['VU']))
return commandArray2017-03-23 22:07:13.005 User: Admin initiated a switch command (37/VU/Set Level)
salvacalatayud
I'm testing this script:
And get this error:
2019-02-24 16:53:00.212 Error: EventSystem: in prueba slider persiana: [string "--..."]:32: 'end' expected (to close 'if' at line 26) near <eof>
Line 26 is: if (devicechanged['Persiana_papas'] ) then
Any idea?
if (otherdevices['Persiana_papas'] == 'Set Level') then
commandArray['OpenURL']="http://192.168.0.117/cm?cmnd=shutterposition%20" .. otherdevices_svalues['Persiana_papas']
print('Level : '..tonumber(otherdevices_svalues['Persiana_papas']))
return commandArray2019-02-24 16:53:00.212 Error: EventSystem: in prueba slider persiana: [string "--..."]:32: 'end' expected (to close 'if' at line 26) near <eof>
Any idea?
