BeNext door sensor not working
(Just moved to this topic from Z-Wave discussion)
I have bought http://www.planete-domotique.com/notice ... OORS_M.pdf, the BeNext door sensor.
They are somehow recognized as hardware and the procedure for inclusion worked smoothly (from the hardware tab I get this (as I bought two of them):),
016 (0x10) Unknown BeNext Door Sensor 2015-07-22 20:17:12 No [Heal node]
015 (0x0f) Unknown BeNext Door Sensor 2015-07-22 20:17:12 No [Heal node]
but they are not recognized by Domoticz. I tried learning Domoticz the sensor but without any succes. It simply does not see this wonderful sensor. Please help me out. Also in the logging I somtimes see the tamper switch come by). I am at my end of the rope here (an old guy learning domotica), what could I do? Any help is much appreaciated
Kind regards,
Bemie
Kind regards,
Bemie
- heggink
- Domoticz version: 12451
Re: BeNext door sensor not working
Same issue here: I ordered 2 of these to replace KAKU sensors that send too many messages on trigger. I can include them but I get a timeout within a few minutes and they do not get recognised again even though the led on the device gives a blip. All subdevices (temp, alarm type and level and the switch) are recognised...
Rob: any thoughts?
Rob: any thoughts?
DASHTICZ 🙃
P1 meter & solar panel
DASHTICZ 🙃
- heggink
Noticed that the devices timeout immediately after being added"
2015-11-25 23:16:08.013 OpenZWave: New Node added. HomeID: 3663738776, NodeID: 30 (0x1e)
2015-11-25 23:16:08.014 OpenZWave: Value_Added: Node: 30 (0x1e), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
2015-11-25 23:16:08.014 (AEOTEC) Lighting 2 (Unknown)
2015-11-25 23:16:08.019 OpenZWave: Value_Added: Node: 30 (0x1e), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2015-11-25 23:16:08.019 (AEOTEC) Lighting 2 (Unknown)
2015-11-25 23:16:08.024 OpenZWave: Value_Added: Node: 30 (0x1e), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2015-11-25 23:16:08.024 (AEOTEC) Lighting 2 (Unknown)
2015-11-25 23:16:08.028 OpenZWave: Value_Added: Node: 30 (0x1e), CommandClass: BATTERY, Label: Battery Level, Instance: 1
2015-11-25 23:16:08.550 (AEOTEC) Lighting 2 (Sensor)
2015-11-25 23:16:08.681 OpenZWave: Value_Added: Node: 30 (0x1e), CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 1
2015-11-25 23:16:08.681 (AEOTEC) Temp (Unknown)
2015-11-25 23:16:18.686 OpenZWave: Received timeout notification from HomeID: 3663738776, NodeID: 30 (0x1e)
2015-11-25 23:16:24.015 New sensors allowed for 5 minutes...
2015-11-25 23:16:24.017 OpenZWave: Node Include command initiated...
2015-11-25 23:16:27.519 Hardware Monitor: Fetching data (System sensors)
2015-11-25 23:16:32.743 OpenZWave: New Node added. HomeID: 3663738776, NodeID: 31 (0x1f)
2015-11-25 23:16:32.743 OpenZWave: Value_Added: Node: 31 (0x1f), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
2015-11-25 23:16:32.744 (AEOTEC) Lighting 2 (Unknown)
2015-11-25 23:16:32.749 OpenZWave: Value_Added: Node: 31 (0x1f), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2015-11-25 23:16:32.749 (AEOTEC) Lighting 2 (Unknown)
2015-11-25 23:16:32.754 OpenZWave: Value_Added: Node: 31 (0x1f), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2015-11-25 23:16:32.754 (AEOTEC) Lighting 2 (Unknown)
2015-11-25 23:16:32.759 OpenZWave: Value_Added: Node: 31 (0x1f), CommandClass: BATTERY, Label: Battery Level, Instance: 1
2015-11-25 23:16:33.251 (AEOTEC) Lighting 2 (Sensor)
2015-11-25 23:16:33.381 OpenZWave: Value_Added: Node: 31 (0x1f), CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 1
2015-11-25 23:16:33.382 (AEOTEC) Temp (Unknown)
2015-11-25 23:16:43.386 OpenZWave: Received timeout notification from HomeID: 3663738776, NodeID: 31 (0x1f)
That's not supposed to happen, right?
H
H
DASHTICZ 🙃
DASHTICZ 🙃
- gizmocuz
Could you also post the log from openzwave?
You can enable 'debug' if you select the controller node, and from the settings enable it.
Do not forget to turn this off...!
in the 'Config' folder there should now be a log file called OZW_Log.txt
- groetg
- Domoticz version: V2.4025
same issue here, is there a solution??
Master: RPI Model 2B
Sub 1: RPI Model 2B
RFX transmitter/receiver 433 Mhz
13 KAKU units (3 window sensors, 1 door sensor, 7 light switches, 1 dusk sensor, 1 motion sensor)
4 IP cam
Meteostick
OTGW
P1 cable
Davis Vantage Pro weatherstation (incl. solar/UV)
Sub 1: RPI Model 2B
4 IP cam
Meteostick
OTGW
P1 cable
- heggink
should have been fixed. check if it's included in the controller group.
DASHTICZ 🙃
DASHTICZ 🙃
- groetg
If the controler id (1) is in the groups of the doorsensor, you mean?
Sub 1: RPI Model 2B
4 IP cam
Meteostick
OTGW
P1 cable
Sub 1: RPI Model 2B
4 IP cam
Meteostick
OTGW
P1 cable
- heggink
I think so. When I installed them, they were not in group 1. adding them manually did the trick. There is a thread on this in the openzwave forum as well (https://groups.google.com/forum/#!searc ... cCPX2vBwAJ).
DASHTICZ 🙃
DASHTICZ 🙃
- groetg
It worked, thanx!
Sub 1: RPI Model 2B
4 IP cam
Meteostick
OTGW
P1 cable
Sub 1: RPI Model 2B
4 IP cam
Meteostick
OTGW
P1 cable
- heggink
great
DASHTICZ 🙃
DASHTICZ 🙃
- Domoticz version: 3.8153
Fibaro door sensor not working
Using Raspberry Pi with Z-wave plus stick, 3 Fibaro door sensors and 3 Fibaro switches.
Door sensors did work fine for 2 months or more, 2 stopped sending a signal when the door opens
(2 weeks and 1 week ago)
the 1 left is still working ok. Added a Fibaro repeater but this did not help.
The sensors are visible in node maintenance and Group And network.
in wave control Panel the 2 sensors not sending a signal have the value Off, think the doors always appear to be closed
also when open. Feels as if it responds but does not send the open signal
What can I do to get this working again.
