Webpage with PHP not working
Marq
Post by Marq »
Hi there,
I am trying to setup PHP on a Raspberry Pi.
What does work: PHP is installed (' sudo apt-get install php5 '). This code is entered in ' ~/domoticz/scripts/firstexample.php '
#!/usr/bin/php
<?php
  phpinfo();
then saved, made executable (' chmod +x firstexample.php ')
executing the script from a CLI (eg. Putty) with (' ./firstexample.php ') gives the expected/desired result
What does not work:
Entering this code in a file ' ~/domoticz/www/secondexample.php ' :
<?php
  phpinfo();
and then calling this webpage from a web browser: http://192.168.1.1:8080/secondexample.php
just results in an echo of the entered code (so not executing the code, and (thus) not displaying the outcome)
I expect that something is missing in the internal webserver.
Can someone give a (link to a) solution ?
Thanks !
Mark
bizziebis
Domoticz version: 3.8805
Re: Webpage with PHP not working
Post by bizziebis »
The built-in webserver of Domoticz is a HTML one. It doesn't handle PHP. If you want PHP, you have to run your own PHP webserver on a different port.
Marq
Post by Marq »
Thanks for the reply.
Any suggestion how to build a webserver which runs php ?
Thanks, Mark
chimit
Domoticz version: master
Post by chimit »
If you have installed php, then probably you also have apache installed.
Put your php scripts in /var/www.
Egregius
Domoticz version: v2024.7
Post by Egregius »
Apache2 and nginx runs fine on RPi.
Marq
Post by Marq »
chimit wrote:If you have installed php, then probably you also have apache installed.
Indeed, this is true. It works. Thanks !
