My stupid Owl script
Aadr
Post by Aadr »
I am not new to Domoticz, but I am a slow learner, I guess.
I am trying to make a script to control the public lights at the soccerclub. I have an Owl device watching the energy comsuption, and when it exceeds the limit of 15 kW the public lights should turn off.
But after searching the forums and trying lots of possibilities, my scripts will not work. And I cannot figure out why not.
Is the someone out there, who will help me with the script I made so far.
The print-command is execuded good, but the switch 'Multi' will not act.
--script Veldverlichting aan dan straatverlichting uit
  c = 15000 --Watt treshold energy usage
  s = otherdevices_svalues['Veld/straatverlichting'] -- gets value from owl energy device monitoring veldverlichting
function five()   -- function to get only usage from string
   local f = (string.sub(s, 1, 5))
   return f
k = five(f)
   if (devicechanged['Veld/straatverlichting'] and tonumber(k) > c)  then -- triggers compare two numbers
       commandArray['Multi 1'] = 'off'  -- switches straatverlichting off
              print("straatverlichting uit")  -- prints status
many thanks in advance.
bizziebis
Domoticz version: 3.8805
Re: My stupid Owl script
Post by bizziebis »
If the print works, then so would your script. The only thing I can see is you set the Multi switch to 'off' instead of 'Off'. But I don't know if its case sensitive.
jmleglise
Domoticz version: 2022.1
Post by jmleglise »
hi,
Something's curious with your function. You have no parameters.
should be :
function five(s) -- function to get only usage from string
return f
try this :
    k = string.sub(s, 1, 5)
           commandArray['Multi 1'] = 'Off'  -- switches straatverlichting off
-- and for debugging :
print('K:'..k)
print('s:'..s)
print('C:'..c)
print(otherdevices_svalues['Multi 1'])
print(otherdevices['Multi 1'])
Last edited by jmleglise on Saturday 06 February 2016 15:28, edited 1 time in total.
My script : https://github.com/jmleglise
RFXTRX433E: Blind Somfy RTS, Portal Somfy Evolvia, chacon IO, Oregon, PIR sensor PT2262
My Last project : Location de vacances a Ouistreham vue mer
KMTronic USB relay
Chinese Z-WAVE: Neo CoolCam
Aadr
Post by Aadr »
Joepie!!!! :D :D :D
Thank you very much, Bizziebis, the command is indeed case sensitive.
jmleglise; thanks for your reply, I will try your improvements as well. I think I can learn from them.
