Scripts for different scenes with one button
nickgosling
Post by nickgosling »
I am new to Domoticz and scripts in general but I wanted to create a Scene that was run when a switch is pressed but run a different scene when the button is pressed again. I was planning on creating a virtual switch that would flip flop and a script that would look at that virtual device and run one of the scenes accordingly. Is that the most straightforward was to do this or is there a better way to activate scenes with different logic using only one button.
Also, in Vera it was obvious where to put scripts. Do they just go in a text file in the Domoticz folder and are referenced to in the script tab under "when activateda"
Thanks,
Nick
nickgosling
Re: Scripts for different scenes with one button
Right so as nobody has replied I've spent about a week watching YouTube videos on lua coding. But then I found that I may be able to acheive this in Blocky. Here is my idea.
Two dummy switches
S1 for scene 1
S2 for scene 2
The trigger is i2 on a qubino module.
So here goes.
Event 1.
IF i2 is triggered AND S1 AND S2 == off
Set S1 to ON and set a scene to do whatever you want.
Event 2
IF i2 is triggered AND S1 == ON
Set S1 to OFF, S2 to ON and set a scene to do whatever you want.
Event 3 - OFF
IF i2 is triggered and S2 == ON
Set S2 to off and turn all the lights off
I haven't actually made this in Blocky as I'm a dad of 2 and working shifts so have really little time but if anyone has a better idea before I try it can you post.
Thanks.
Sent from my Nexus 5X using Tapatalk
mrf68
Post by mrf68 »
Suppose you have 2 lights you want to switch. When you press the virtual switch, you can check if light 1 is "On". If not, then turn on light 1. If light 1 is " On", turn light 2 "On".
If you want completely different things to happen, then I think you need to build in a check on how often the button is pressed within a specific period of time. In LUA this is possible, I don't know how to do it in Blockly.
Regards,
Martin
nickgosling
Re: RE: Re: Scripts for different scenes with one button
mrf68 wrote:Hi,
Regards,
Martin
Thank for the reply Martin. I'll give it a go in Blocky and if not will attempt some lua code. How would you check how many times a button is pressed jn lua. That sounds like something I could apply.
Nick.
bizziebis
Domoticz version: 3.8805
Post by bizziebis »
I do it with LUA like this:
if devicechanged['Blinds_Toggle_1'] == 'On' then
	if otherdevices['Blinds1'] == 'Open' then
		commandArray['Blinds1']='On'
	elseif otherdevices['Blinds1'] == 'Stopped' then
		commandArray['Blinds1']='Off'
I only press the 'ON' button of the remote to toggle trough different states of my blinds.
You can also trigger a scene with this, then u use:
commandArray['Scene:Blinds']='On'
nickgosling
Thank you for the reply. I'm going to experiment with this later. I'm going to make the virtual switches part of the scene so that each device in a particular scene is unique. That way it will satisfy the if statement.
nickgosling
So this is my first attempt with LUA. I haven't done any programming scripts since university and that is going back some years. But it works. I forgot how satisfying it is when a script runs correctly but it works anyway.
So this is my script:
if (devicechanged['motion sensor'] == 'On' and otherdevices['Dummy 1'] == 'Off' and otherdevices['Dummy 2'] == 'Off') then
commandArray['Scene:Scene 1']='On'
commandArray['Dummy 1']='On'
if (devicechanged['motion sensor'] == 'On' and otherdevices['Dummy 1'] == 'On' and otherdevices['Dummy 2'] == 'Off') then
commandArray['Scene:Scene 2']='On'
commandArray['Dummy 2']='On'
commandArray['Dummy 1']='Off'
if (devicechanged['motion sensor'] == 'On' and otherdevices['Dummy 1'] == 'Off' and otherdevices['Dummy 2'] == 'On') then
commandArray['Scene:All off']='On'
commandArray['Dummy 2']='Off'
As I'm new to the language if there are any language housekeeping things that would make this simpler then I would be keen to know them. Obviously my first issue is that if I change any names in Domoticz I will need to re write the scripts. The other thing would be I'm going to have a lot of Dummy switches to make this work throughout my house for all of the other rooms.
