[689] Hyperion integration
Just set up an Hyperion solution.
Hyperion is a DIY Ambilight for TV/movie etc etc.
This well documented : https://github.com/tvdzwan/hyperion/wiki and really stable
It's works as a web server.
Using it with XBMC is a real pleasure, and adding a video grabber you can appli Hyperion to your ISPTVbox or DVB reciever (if not inclued on your TV).
Hyperion can be use as "light" with Android/ios/webapp, and got some cool effect, of course we can use script to drive it for "effects", but not really user friendly for RGB color.
As this solution, is stable, well documented, can give a real WAF to our home automation, this can be really cool if it can be Drive by Domoticz :
Somes exemples :
- When Movie/tv show is end, turn TV and all accessorie OFF
- When it's lover time, set hyperion on a charming candel mode (using a 433 Remote or NFC Tag, or any thing you can use to define this).
- When is party (defin by a google calendar event) set Hyperion on disco mode
Somes exemples :
http://domo-attitude.fr
- iMars
- Domoticz version: Latest
Re: [689] Hyperion integration
With the following commands you can change the effect/color:
Edit: wrong button, submit instead of preview
With "runcommand" in a LUA script you can execute a command:
Create a device this way: http://blog.quindorian.org/2015/01/esp8 ... -of-x.html
And use the following script (not the one on the page mentioned above):
This create a dimmer which can fade only one color (I've got 4 dimmers for my Hyperion).
Note: Domoticz has priority 10, XBMC/Kodi has priority 1. When movie is playing, i've got ambilight, when movie stops, it goes back to the color set with domoticz
echo '{ "command": "effect", "effect": {"name": "Full color mood blobs"}, "priority": 100 }' | nc x.x.x.x 19444
echo '{ "command": "clear", "priority": 100 }' | nc x.x.x.x 19444
echo '{ "command": "color", "color": [255,255,255], "priority": 100 }' | nc x.x.x.x 19444
runcommand = "echo '{ "command": "color", "color": [255,255,255], "priority": 100 }' | nc x.x.x.x 19444"
Where x.x.x.x is ofcourse the IP of hyperion
pi@domoticz:~$ cat domoticz/scripts/lua/script_device_MoodLight.lua
DomDevice = 'MoodLight' --name device
IP = 'x.x.x.x' -- ip address hyperion
Port = '19444'
-- default color (one color, dimmable)
DomR = 255 --RED
DomG = 31 --GREEN
DomB = 0 --BLUE
if devicechanged[DomDevice] then
if(devicechanged[DomDevice]=='Off') then
DomValue = 0;
print('Turn '..DomDevice..' off...')
elseif(devicechanged[DomDevice]=='On') then
DomValue = 31;
print('Turn '..DomDevice..' on...')
DomValue = (otherdevices_svalues[DomDevice]);
print('DomValue for '..DomDevice..' changed to:'..DomValue)
DomR = math.ceil(DomValue / 31 * DomR)
DomG = math.ceil(DomValue / 31 * DomG)
DomB = math.ceil(DomValue / 31 * DomB)
runcommand = "echo '{ \"color\": [" .. DomR .. "," .. DomG .. "," .. DomB .. "], \"command\": \"color\", \"priority\": 10 }' | nc " .. (IP) .. " " .. (Port) .. " ";
print (runcommand);
os.execute(runcommand);
pi@domoticz:~$
- iMars
Ofcourse a full integration would be even better! Or a dummy rgb dimmer, which can pass the corrosponding hex code to a LUA script, that combining my script would make it possible to have ONE switch for all kinds of colors
Thanks for your help !iMars wrote:Ofcourse a full integration would be even better! Or a dummy rgb dimmer, which can pass the corrosponding hex code to a LUA script, that combining my script would make it possible to have ONE switch for all kinds of colors
I really love this idea, and a rolling menu to choose which effect we want when "planning" a scene.
Very Nice Blog !!
I plan to do some looks like of your Ikea Hack but with a DIY Philips Hue Bridge (who act as a bulb too : https://github.com/sticilface/Esp8266-Hue) + ws2812b + Wemos Mini D1 : bridge part is ok, and well reconnize by domoticz, waiting my ws2812b strip.
First feedback : perfect !
Just one issue :
- i use v4l2 grabber, not kodi ones.
when turn "virtual dimmer" off that doesn't enable v4l2, my led strip stay off until i restart hyperion.
Any idea ?
Just one issue :
Any idea ?
Got a solution : sending clearall when dimmer is off, freeing v4l2 led strip.
Now have to know how set this on lua script
- iMars
Use my script, and instead of color 0,0,0 > use echo '{ "command": "clear", "priority": 100 }' | nc x.x.x.x 19444deennoo wrote:Got a solution : sending clearall when dimmer is off, freeing v4l2 led strip.
Port = '19444'
DomR = 255 --RED
DomG = 31 --GREEN
DomB = 0 --BLUE
--DomValue = 0;
runcommand = "echo '{ \"command\": \"clear\", \"priority\": 10 }' | nc " .. (IP) .. " " .. (Port) .. " ";
print (runcommand);
os.execute(run command);
return commandArray;
DomValue = 31;
print (runcommand);
will try it ! thanks !
Good blog by the way !
It perfectly Works !
Thanks for your help !!
Next step ?
Get a "color picker"
Set One Dummy dimmer for each color who write on variable is value.
Set One Dummy dimmer for "lighting level" (Value variable for Hyperion remote / Level Variable for domoticz dimmer)
When Moving one of the dummy color slider it send to hyperion Red Dimmer + Blue Dimmer + Green Dimmer value to flollow :
Where DomR is value set last time you move slider
Where DomG is value set last time you move slider
Where DomB is value set last time you move slider
- iMars
I don't want to use this option, I've tried it, and its not handy. Only 31 red's, 31, blue's and 31 green's. Stil, you should be able to create 32.768 different colors, yet not do-able. I've created 4 sliders for the most used colors: light yellow for normal light, yellow, orange and red. All 4 with sliders like my first posted script.deennoo wrote:Next step ?
Where DomR is value set last time you move sliderCode: Select all
OK !
Thanks for your feedback
Next step again ?
Made my hyperion follow my Milight color value...
Looks crazy that we are only 2 using hyperion & domoticz
Next step again ?
I/m also using the solution from hyperion and was looking for a similair olution you are working on
Raspberry Pi B+
RFXCOMe
Kaku switches
x10 Security System
My system also act as XBMC
Raspberry Pi B+
RFXCOMe
Kaku switches
x10 Security System
Got a New probleme,
For fun i want some switch to load and stop effect :
Base on iMars elements i made this script, no lua error but no reaction from hyperion :
Any Idea please ?
DomDevice = 'Hyperion Arc en Ciel' --name device
IP = '192.168.0.245' -- ip address hyperion
Port = '19444'
print (runcommand);
print('Arc En ciel Rapide !')
runcommand = "echo '{ \"command\": \"effect\", \"effect\": {\"name\": \"Rainbow swirl fast\" }, \"priority\": 100 }' | " .. (IP) .. " " .. (Port) .. " ";
- iMars
Take a good look at your codedeennoo wrote:Got a New probleme,
Any Idea please ?Code: Select all
commandArray = {} DomDevice = 'Hyperion Arc en Ciel' --name device IP = '192.168.0.245' -- ip address hyperion Port = '19444' if devicechanged[DomDevice] then if(devicechanged[DomDevice]=='Off') then print('Turn '..DomDevice..' off...') runcommand = "echo '{ \"command\": \"clear\", \"priority\": 10 }' | nc " .. (IP) .. " " .. (Port) .. " "; print (runcommand); os.execute(runcommand); return commandArray; elseif(devicechanged[DomDevice]=='On') then print('Arc En ciel Rapide !') runcommand = "echo '{ \"command\": \"effect\", \"effect\": {\"name\": \"Rainbow swirl fast\" }, \"priority\": 100 }' | " .. (IP) .. " " .. (Port) .. " "; os.execute(runcommand); end end return commandArray
You can run the command from a terminal (I work on a Mac, If you work on Windows, ssh with putty to domoticz or your hyperion linux ).
I ran your command: echo '{ "command": "effect", "effect": {"name": "Rainbow swirl fast" }, "priority": 10 }' | <my ip> 19444 and it didn't work... because you've forgotten the "nc" right after the "|" before your <ip>
The right syntax is: echo '{ "command": "effect", "effect": {"name": "Rainbow swirl fast" }, "priority": 10 }' | nc <your ip> 19444
I fixed your code:
Port = '19444'
print (runcommand);
-- skip this, its not needed -- return commandArray;
runcommand = "echo '{ \"command\": \"effect\", \"effect\": {\"name\": \"Rainbow swirl fast\" }, \"priority\": 10 }' | nc " .. (IP) .. " " .. (Port) .. " ";
Thanks for this what mean "nc" ?
Small improvement for those who run Domoticz on a Syno and want to use netcat command.
It appear that Netcat on a Syno stay ON and don't kill connection this give an error on Domoticz Log because LUA script run more than 10 secondes, and Domoticz freeze during this time.
You just have to had -c value to your netcat command, this give :
No more error anymore
runcommand = "echo '{ \"command\": \"effect\", \"effect\": {\"name\": \"Rainbow swirl fast\" }, \"priority\": 10 }' | nc -c " .. (IP) .. " " .. (Port) .. " ";
- Domoticz version: Left
I don't know if anybody is intereseted, but i made a python plugin (for the beta version):
https://github.com/ericstaal/domoticz/t ... n/hyperion
Allows you to control rgb values and select mode
will test it this night ! thx !
Some question about it : did you parse effect from hyperion or did your already write on plugin usual effect ?
how to install it ? just paste the plugin.py file ?
