On FOR variable possible?
SiSu82
Post by SiSu82 »
Im doing some simple math in a lua and trying to set a switch ON for the calculated time
commandArray['Lamptest'] = 'On FOR testtime'
testtime is in this case a local variable in the lua script, whitch aint working, is it even possible?
jvdz
Domoticz version: 4.107
Re: On FOR variable possible?
Post by jvdz »
Assuming testtime is a variable in LUA this should work fine:
commandArray['Lamptest'] = 'On FOR ' .. tostring(testtime)
Jos
SiSu82
Post by SiSu82 »
jvdz wrote:Assuming testtime is a variable in LUA this should work fine:
Jos
Thx alot Jos
havnegata
Domoticz version: V4.10162
Post by havnegata »
Trying to understand the concept of variable. Why is it an advantage to use a variable in your script instead of just f.ex 'On FOR 5' ?
SiSu82
Post by SiSu82 »
havnegata wrote:Trying to understand the concept of variable. Why is it an advantage to use a variable in your script instead of just f.ex 'On FOR 5' ?
Because im doing some math in the LUA script depending on how cold it is outside, whitch makes me wanna put a switch on for X min.
On FOR xxx Minutes would ofc work but better to use the calculated value instead.
havnegata
Post by havnegata »
Thanks for the reply, I'm beginning to understand, but can you please post the code, that way it's possible to get a greater understanding :-)
SiSu82
Post by SiSu82 »
havnegata wrote:Thanks for the reply, I'm beginning to understand, but can you please post the code, that way it's possible to get a greater understanding :-)
Will post it later this weekend, atm im doing some small changes to the code =)
havnegata
Post by havnegata »
Thanks, awaiting :-)
Sent fra min Nexus 7 via Tapatalk
